SOURCE: sony home theatre model dav-hdx265
hmmm..didn't know you could do that? Do you have the user manual on hand?
SOURCE: Getting an error display as
Turn off your unit at the power button. Check speaker outputs for a short circuit - also check other end of speaker cables for a short. If you can't find an obvious problem then disconnect all speakers and power up the unit. If all is OK then connect speakers one at a time (this should be done with the unit powered OFF) and power up after each conection. This should identify which output is causing the problem.
If that does not work then it's an internal fault that will require a service engineer to identify - but I hope that is not the case!
SOURCE: I have a sony DAV DZ230 home theatre system
on my home theater display it shows protector push power
