Question about Ovens
How do I refix a loose oven door handle on a Prima oven Model Prs0102
One side of the handle has become detached from the door. I need to get the door apart to access the bolts that hold on the handle.
SOURCE:
  • 65 Answers
SOURCE: 2000 ford explorer door handle
I assume you mean the drivers door. You need to remove the door panel and there are two nuts on the inside holding it on.The door panel has three retaining screws and you need to locate and remove. You then slide the door panel up and then remove it.DON'T pry the panel out you will break it.One screw is on the bottom of the panel. You should see that one. The other ones are under the door switch area and the inside door handle trim.Some have one under the remote mirror trim but not likely.That should give you access to the door handle nuts. Good Luck and I hope this helps you. Thanks Dan
Posted on Jun 21, 2008
  • 11 Answers
SOURCE: Inside glass of zanussi oven
Works on Zanussi ZBF 660 X Built In Oven.
To remove door:
Not sure if you still need to get your oven door off still but I have the same oven and have spent the last several hours trying to remove it and searching the web to discover how to remove it until I have just discovered a wonderful video tutorial on YouTube www.youtube.com/watch?v=hSzc4Uqbbr8
that discribes exactly how to do it (just copy and paste it into your address bar.
It is the fourth and final instruction in the video but it really is easy.
The hinge is a latching over system type that folds back into the glass apparently.
Just get a screwdriver and where the end of the hinge dissappears into the housing of the oven just flick up the hinge with the screwdriver and the locking mechanism folds back towards you and the glass.
Once both are done just jiggle and pull up the door and it will remove easily....godsend!
Regards,
DIYDIM
Posted on Dec 05, 2008
appldoctom
  • 311 Answers
SOURCE: loose oven door handle on kitchenaid gas range
youl have to take apart the door.the screws are on the other side of the glass/framing
Posted on Jan 01, 2009
  • 26 Answers
SOURCE: Mazda 5 replacing external handle on sliding door
Your door should be held on with clips. Removing the panel is sometimes hard, just take a good WIDE flat head screwdriver, and whatever tool needed to remove the screws holding the panel on, and be careful. Check underneath the panel, by the inside handle, and the arm point for screws. Once removed, take your WIDE screw driver, and don't quite pry them off, more or less try to get it underneath and pull towards yourself. There is no real easy way, just try to be patient with it, and if you hit any binds, look for more screws, its just a matter of patience for sure.
Posted on Feb 14, 2009
I had the same problem. We took the door off completely & turned it upside down. There are screws on the bottom of the door, take them out, take off bottom trim piece that holds the outside glass panel in place, remove glass panel and you can access the door handle screws and clean the inside of the glass while you are at it.
Posted on Feb 17, 2009
How do i cleaning inside oven glass door on a prima prs0102 oven
The glass panel is a sealed double pane. Caning is not recommended.
Jan 14, 2017 | Ovens
Oven door handle one side not attached to door other side loose
look around the outer edge of the door a few screws hold the 2 halves together caution do it on a flat surface as the glass can fall out .
Sep 01, 2016 | Neff Ovens
My neff oven's handle has become loose. I cannot see any screws. how can i tighten handle ? the model is U1422 oven.
You need to remove the inner glass panel, should be 2 screws at top and 2 at bottom and remove. The screws for the handle are behind this
Mar 02, 2011 | Neff U1421 Double circotherm Electric Oven
The hinge to close the oven door came loose from the oven how do we fix this
Oven doors detach by lifting. take the door off and it should be obvious what to fix. Be careful when handling the hinge as it has a strong spring and can give your fingers a real wack.
Jan 04, 2011 | Whirlpool Ovens
Oven door handle is loose on Model RF366BXD self cleaning range, how do we tighten the door handle?
Extend your door hinges and remove entirely over to a table or other flat surface where you can do a step-by-step dis-assembly. Unfortunately, to get at the interior of the handle unit, it's the final stage of the taking apart. Begin by removing the bolts at the bottom of the door, then the main panel and side flanges can be removed. (You can give your glass a good cleaning at this point also.) There are 2 bolts to remove to free up the handle unit, and now you can easily tighten (or replace as needed) the 2 pairs of handle bolts. Reverse your order to re-assemble, and put your door back on the oven. It's not as bad an exercise as it would appear. Just take your time and watch what you're doing. I used the hinges as a shim, and had it laid out on a pool table for easy, elevated examination.
Dec 09, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The door handle has come appart. How does the
I'm not mechanically-inclined, but the frustration of an oven handle hanging by one side prompted me to try to become mechanical. Remove the entire door from the oven by working the hinges. Then put it on a flat surface (I used a pool table) and let the hinges act as a shim. Remove the bolts from the bottom edge and lift out the main panel and the end flanges. Carefully set the glass aside and it's an opportune time to clean it. You'll see two bolts which hold the door handle assembly in-place. Upon removing those, you'll finally be able to get at those interior door handle bolts. One of mine was missing a lock washer. I found adequate replacement parts and then reversed the process to re-assemble the door and place it back on the oven. This seems to be a common defect with this model, and it's unfortunate that the handle's bolts can't be assessed more easily, but when you go at it systematically, it wasn't as difficult as I had feared.
Jul 02, 2010 | Whirlpool RBS275PD Electric Single Oven
The door handle of my oven whirlpool gold model no GGP84803 is loose I try to get it off by prying it from the top with no luck seem to be jam or locked I am not sure how to proceed.
I had same problem, fixed by removing screws under door and removing side panels . Then remove front glass ( 4 screws under glass ) and remove other screws behind glass to remove handle and then tighten 4 screws on handle. Works great.
Dec 29, 2009 | GE Ovens
Neff Oven handle loose
The door can be seperated by screw on the side of the door, Put lock washers to insure futer tightness.
Mar 12, 2009 | Ovens
Door hinge of oven detached on one side
two hidden levers on end of hinges. When raised, door able to be re-inserted or completely detached.
very simple once i discovered levers on the hinges.
Dec 19, 2008 | Ovens
Door won't open after self cleaning.
it is locked the leaver has become detached from the door latch and even though the leaver moves the lock part doesn't have you tried it lately push in on the door and try to move the leaver if that doesn't work get a wire coat hanger make a Small hook and from the left hand side see if you can snag the hook and pull it over ive done that before theopen end of the hook should point up start just abve the door gasket about halfway over well i cant reamber which way the latch moves but im sure you can figure it out push slighty in on the door after you hook the latch but try to open it fist some have asensor that wont let the oven door open till its cool enough to be safe let me know
Dec 31, 2007 | Ovens
Ovens Logo
48 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
