Lawn-boy 6.5 ft-lbs cross torque kohler 149cc with smart choke
SOURCE: I NEED THE TORQUE SPECS.
They are probably 8mm bolts and 17- 20 seems to be where they would be
SOURCE: torque specifications cylinders head bolts
for 1.5/1.6L DOHC, 18 Ft-lbs + 70deg + 70deg + 50deg
for 1.8/2.0L DOHC, 18Ft-lbs +90deg + 90deg +90deg
SOURCE: what is the rocker arm torque (ft/lbs.) for a 1995
OK here you go. there are three different engine codes for that model and engine size. first is the D15Z1. This one is 14ft.lbs. Then you have D15B7 and D15B8 these two are the same at 16ft.lbs.
SOURCE: toyota 4A-FE connecting rod bolt torque spec ?
what is the torque specs on 4afe 1.6 toyota corolla connecting rod & cylinder head
