Question about Janome Sewing Machines
My janome 1step model 2319S button hole maker allows me to go forward but not reverse
SOURCE:
SOURCE: Janome 1 Step - model
Yes, fixed the problem this time - how, just fumbled around until it stayed put.
I find that I need Visual aids as well as the written word.
Since this was a 'cheapie' Model the 1 step, I guess there's no specific manual for it.
Many thanks for your time and effort - I know who to go to if I have other problems, thanks again.
Beryl Ross
Posted on Jan 27, 2009
SOURCE: Janome Excel 5124 reverse lever
If you pull the bottom off the machine (half a dozen screws) there is a cam on the main drive shaft. The cam is probably jammed in the reverse position due to lack of lubrication on the shaft. You can move the cam back manually and it will operate in forward direction. It appears that the shaft needs lubrication.
Posted on May 02, 2009
  • 297 Answers
SOURCE: My Janome JD1818 will sew in reverse but not forward.
Switch broken, have it replaced
Posted on May 06, 2009
  • 96 Answers
SOURCE: Janome machine going backwards
sounds like a screw may have become missing to keep the reverse knob in its proper position so it is backwards inside the machine
Posted on Dec 13, 2009
SOURCE: I need a Janome 2319S sewing machine manual
try janome website first or a dealer
sewingpartsonline.com
sewusa.com
sewingmanuals.com
Posted on May 13, 2012
Does the janome DMX300 have a 1step button hole or a 4 step?
If you click on "View Sewing Machine Features & Benefits" under "Description," it indicates it has an auto one-step buttonhole
Janome DMX300 Deluxe Sewing Machine
Mar 04, 2018 | Janome Sewing Machines
Have a janome 2319s can I quilt and what tension do I need Barbara
You can quilt with pretty much any sewing machine. But, are you asking about piecing quilts or free motion quilting? You should be able to do both but they are very different projects and require a lot of different settings and accessories. Tension is correct when the top and bobbin threads meet in the middle of the fabric being sewn. Tightening or loosening the top tension should help achieve that.
Jan 22, 2018 | Janome Sewing Machines
I am looking for a manual for a janome 1 step model 2319s can you help me please
Search the internet for:
Manufacturer + Model + the word "Manual"
Nov 13, 2015 | Janome Sewing Machines
The reverse button does not work
The button is a relay switch and is an electronic component
Quite easy to replace, but you need to get parts from Janome Authorised Dealer
Feb 28, 2015 | Janome D'cor Excel Pro 5124 Mechanical...
The button holes that I want to do are larger than the automatic buttonhole will do on my Janome MS5027, is there a way that they can be done manually?
Mark your garment with chalk taking care to mark the start point and end points and a straight line to follow. Set your machine up for a fairly wide bar tack (zig zag in place) Then position the needle left and set it up for a satin stitch (fairly narrow) slowly stitch forward until you get to the end mark. Then do another bar tack. At this point you move your needle to the other side and satin stitch in reverse until you get to the first bar tack.
I would test this on a scrap piece first. Then proceed.
Jul 25, 2012 | Janome Sewing Machines
sewusa.com
sewingmanuals.com
May 12, 2012 | Janome Sewing Machines
Janome New Home mx3123 reverse button not working
1/28/13 - I have Janome Harmony 2049 that was initially sewing forward with no reverse and then after about 12 inches of sewing would ONLY sew in reverse. After spending an hour getting the plastic housing off...I was able to locate the shaft that made the reverse. It needed lubrication and after working it in and unjamming the part from the down position, the forward and reverse now work!
Huh, right? Hope it continues to work well. It is a smooth running machine, otherwise. Good luck!
Apr 05, 2010 | New Home MX-3123 Computerized Sewing...
Janome machine going backwards instead of forwards. Goes forward if I hold the reverse button down.
Dec 13, 2009 | New Home MX-3123 Computerized Sewing...
Janome 1 Step - model 2319S. How to replace Floating bobbin holder etc. also do you have a maual for this model?
Beryl Ross
Jan 26, 2009 | Sewing Machines
Sewing Machines Logo
21 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
