SOURCE: I have a Sony Trinitron
Please post the blink count of the standby light. That will indicate the circuit in which the problem was found that triggered the "protect" mode. Further details can be provided once that count is available.
Thanks,
Dan
SOURCE: Cannot power up my Sony Trinitron KV-34HS510.
> makes a noise
This doesn't tell us much; is it a click or a sharp snapping sound?
The first can be a relay turning on, the second is most likely related to a high voltage discharging.
If it is a relay, then the set could be trying to protect itself from an overload or the power supply has failed; the blinking ON LED is pointing toward that.
If it is a high voltage discharge (you may be able to see it through the vents in the rear housing) then it is possible that an accumulation of dust and household airborne contaminents has created a path that can be removed with some targeted cleaning.
SOURCE: Sony FD Trinitron WEGA KV-34HS510 34
