Don't open two programs that uses webcam, for example: if you have skype application opened with video call you can use the webcam at yahoo messenger. make show application that requires one web cam features like video calling are online opened when needed.
if the is a hidden program that you sure to have close it that is still in process, then open the task manager and click on applications, you will see and end it process there, if the problem persist then restart the computer
SOURCE: Overiding the webcam built-in to a Dell 1720 laptop
Normal
0
Right click on My Computer and click on PROPERTIES.
Then click on DEVICE MANAGER, and then click on Imaging Devices.
Next click on the + and then on the camera, right click and then click on
DISABLE.
Then click on the Red X in the upper LEFT corner.
Then get out of that and install your new camera.
Make sure to disconnecting the Camera from the USB
port and reinstall the software program. When the program asks
you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
SOURCE: No video when using quickcam pro 9000 on google chat (gchat)
I had this problem but I fixed it. The google chat uninstaller does not uninstall everything. Go to the hidden folder Application Data of the default or local user in the Documents and Settings folder of the C drive, you will find the plugin folder for google chat. Delete it and then reinstall the plugin and it will work.
C:\Documents and Settings\Joe\Application Data
SOURCE: video webcam logitech 9000 pro is to slow on pentium 4 2,6 GHz XP
http://www.logitech.com/index.cfm/webcam_communications/webcams/devices/3056&cl=US,EN
go to this link, scroll down to instant messeging and click on learn more.
follow setup instructions.
if this does not help, come back and i will try to work out another solution.
SOURCE: 'no sound' when i use my Logitech Pro 9000 with Windows Messenger
Normal 0
See section C. Windows LiveMessenger in the info below to setup the Audio & Video.
Also send this to your familyand friends so they have there computer setup properly.
Web Camera’s have to besetup on the program they are to be used with. Just installing the camera on your computer does not set it up tobroadcast on messengers or Skype.
Each program has Options that have to be setup in order forthe Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
The camera and audio should function properly. Your friends and Family will now be able tosee and her to you.
C. Windows LiveMessenger:
Go to thissite http://download.live.com/?sku=messengerand download Windows Live Messenger.
NOTE: Your audio andvideo should work. Enjoy.
When done both the Audio and Video will function properly soyou can chat and see family or friends you are connected to.
Hopethis helps. Bud
SOURCE: sound problem on my logitech pro 9000 install on mac
Check quick time settings.
See if other video files played in quicktime have voice.
