Dishwashers Logo
p
paul smith Posted on May 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Bellini dishwasher stopped working yellow lights flash and beep ten times and tells me we have no water supply but we have plenty what do I do next regards paul
Your Consultant
Level 3:
Master:
  • Master 825 Answers
  • Posted on May 27, 2019
Your Consultant
Master
Level 3:
Master:
Answers
825
Questions
Helped
205967
Points
1873
If the water is on, then the next thing in line is the water valve. Either bad or a bad contact. If not then the control is bad.
5 Related Answers
Anonymous
  • 19 Answers
  • Posted on Feb 05, 2009
SOURCE: Siemens dishwasher, water supply interupted
I'm sure you disrupted the sequencing! If its full of water, drain it. If its got no water in it, then manually fill it! This should get you back into sequence and up and running.
Anonymous
  • Posted on Oct 25, 2009
SOURCE: hotpoint aquarius FDW60 FAULT
dishwasher runs for 1 min then stops and 40c indicator and 50c indicator flash on and off together it pumps water out then stops
Anonymous
  • 34 Answers
  • Posted on Aug 13, 2010
SOURCE: After selecting a program, the
Basically the dishwasher is telling you there is a fault - Not so useful I know! Plug out the machine and leave it for five minutes and see will it reset. If that does not work, you will need to reset it manually. To do this consult the manual. If you don't have a manual, go to http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do and down load one. Good luck!
Sam
  • 3247 Answers
  • Posted on Dec 15, 2010
SOURCE: Hoover HED 6612/1-80 dishwasher all four lights
Not sure if you have got a user manual for this dishwasher. You can download one from this site.
You have a flood situation inside the dishwasher. See page 12 of the manual. There may be no water at the bottom of the machine but there is some overfill occuring. Also see error codes on page 13. This can be either because the flood detection circuit is faulty and giving false trigger or there is water in the base of the dishwasher housing due to leaking door gasket or hoses.
Some things to try. Turn mains power off and back on and see if there is any difference.
If not, then turn power off and pull dishwasher out from the kitchen benchtop. Put a few towels on the floor and tilt the dishwasher side to side on the base and see if any water comes out. Wait 5-6 minutes and turn power back on. See if it makes any difference.
Anonymous
  • Posted on Mar 06, 2011
SOURCE: bellini ice maker even though I put water in it
I have same problem and do not know
My bellini dishwasher rinse Ais is on and water supply light blinks same time?
When the water supply light blinks and the rinse aid light is on in a Bellini dishwasher, it indicates that the dishwasher is not receiving enough water or the water supply is interrupted. Here are a few things you can try to resolve the issue:
  1. Check the water supply: Make sure the water supply valve is turned on and water is flowing properly to the dishwasher.
  2. Check the water inlet valve: The water inlet valve is responsible for controlling the water flow into the dishwasher. If it is faulty, the dishwasher may not be getting enough water. You can check the valve with a multimeter to see if it is working properly.
  3. Check the water pressure: Low water pressure can also cause this issue. Make sure the water pressure is at least 20 psi.
  4. Clean the inlet filter: The inlet filter could be clogged and preventing water from entering the dishwasher. Clean the filter and see if it helps.
If none of these steps resolve the issue, you may need to call a technician to diagnose and fix the problem.
Feb 18, 2023 • Dishwashers
New Bellini dishwasher- No water source error- using for the first time ever
It sounds like there may be an issue with the installation or water supply to the dishwasher. Here are a few things you can try to troubleshoot the problem:
  1. Check the water supply: Make sure that the water supply valve is fully open and that there is adequate water pressure. Also, check that the water supply hose is properly connected to the dishwasher and to the water supply valve.
  2. Check the water inlet valve: The water inlet valve is responsible for controlling the flow of water into the dishwasher. Make sure that the valve is fully open and that there are no kinks or blockages in the hose.
  3. Check the float switch: The float switch is a safety device that prevents the dishwasher from filling with water if the dishwasher is already full. Make sure that the float switch is not stuck or malfunctioning.
  4. Check the drain hose: Make sure the drain hose is properly installed and not clogged.
  5. Check for leaks: Make sure that there are no leaks in the water supply hose, the inlet valve, or the drain hose.
  6. Contact the manufacturer: If you have tried all of the above steps and are still unable to fix the issue, contact the manufacturer for further assistance. They will be able to provide you with additional troubleshooting steps or advice, or they may need to send a technician to repair or replace the dishwasher.
It's important to note that if the dishwasher was not installed for 2.5 years, it is possible that some components may have become damaged or malfunctioned due to lack of use, and you should contact the manufacturer or a professional service technician for further diagnosis and repair.
Jan 09, 2023 • Dishwashers
3answers
My Bellini dishwasher is also beeping 10 times and sounds like water is not coming into the dishwasher any suggestions on what I can do? Please and Thankyou.
f the dishwasher is beeping alongside blinking lights, the anti-flood device may have been activated. This means that the sensors have detected water in the casing and have stopped working to prevent flooding. You'll need to tilt the appliance to get rid of excess water, and sponge off water in the base.
Jul 10, 2021 • Dishwashers
My hanseatic dishwasher is beeping and flashing on the little glass symbol and it stopped working.
https://removeandreplace.com/2015/12/21/dishwasher-has-beeping-sounds-blinking-lights-how-to-reset/
Dishwasher lights flashing or blinking. The heating element heats up the water to operating temperature. If the water doesn't reach the proper temperature after a set amount of time, a light on the control panel might start flashing. ... If the drain pump is not working, a light on the control panel might start flashing. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/28---/Dishwasher-Lights-Flashing-Or-Blinking
Flashing lights and or beep sounds can mean the dishwasher problem was from a power surge or power outage. You can unplug the dishwasher from power or shut off the breaker to the dishwasher for 1 minute. This may reset the dishwasher and get it back to working order.
May 12, 2020 • Dishwashers
1helpful
Hello, my Haier dishwasher stopped mid cycle after about 10 mins and will not restart. the lights just flash and buzzer sounds. Can anyone help please?
Have the same problem with mine and have found no solution in the manual or web. four lights flashing and beebs ten times every ten seconds, water coming in and draining out constantly, very frustrating!
Cda cw 494 - dishwasher makes beeping noises and stops halfway through cycle . will restart if turned off but will not complete . doesnt seem to be filling properly .now and then does complete cycle and...
Greetings,
usually, open and close door..then start counting the flashes. these will give you your fault code. The code then tells us where to go from there. off hand, i would say you have a heater problem.. Either, the water is not getting hot enough because of a faulty heater, or faulty thermostat. The button above the green light that flashes try and hold that down for a minute to reset....let me know about the flashes
My ADP 8342 continually sounds 10 beeps, stops the...
Refer the user guide for the error message meaning. Contact service provider.
Before that make sure that the water supply to the inlet is having free flow.
May 21, 2010 • Dishwashers
Top Dishwashers Experts
Mike Cairns
Mike Cairns
