My Hisense tv kept going up to volume 100. Recently installed Firestick using the Firestick direction. Reset my tv to factory settings and let the tv redo the Firestick too. Volume working good now.
Hello Ginnie, it may be that your remote control has the VOL-locked button and produces the fault, to test the batteries to the remote control and check if it continues to do so.
Another option may be that the VOL- control, on the TV, is locked or has some internal dirt and generates a false contact that could cause the failure
Check these points to see if you have problem solution
If not consult a specialized technical service
I hope I can solve the problem
Greetings Franco Dosil
Hola Ginnie, puede ser que su control remoto, tenga el bot?n de VOL- trabado y produzca la falla, para probar saque las pilas al control remoto y compruebe si lo sigue haciendo
Otra opci?n puede ser que el control de VOL- , en el televisor, se encuentre trabado o tenga alguna suciedad interna y genere como un falso contacto que pueda provocar la falla
Compruebe estos puntos a ver si tiene soluci?n del problema
Sino consulte a un servicio t?cnico especializado
Espero pueda resolver el problema
Saludos Franco Dosil
SOURCE: Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
SOURCE: volume keeps going up by itself
help the volume on my tv keeps going up and no one is touching it! please help. my parents cannot afford a new tv
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
SOURCE: RCA HDTV Monitor; menu popping up and volume going down
The small signal board needs replacement. You can get replacement small signal boards from www.tvrepairworld.com
