Question about Car Audio & Video
Hey sir I have a problem I have DVD double vm9022 but I when I need using cd or DVD but I can open but not full half and also not close I don't know why
SOURCE:
  • 158 Answers
SOURCE: DVD Drive won't stay closed
i would sugest getting it repaired if it's in warrenty if not then get a new one the prices are low enough for replacement drive. good luck on this one
Posted on Aug 15, 2007
map9966
  • 2351 Answers
SOURCE: Opening CD/DVD Drive from the screen
Click the link & download this free utility called HotKey CD-Eject 2.3 http://www.freedownloadmanager.org/downloads/HotKey_CD-Eject_12875_p/free.htm
If you have pop-up blocker you will need to shut it off so the download window can open. I scanned the program for virus& tracking code, it's clean.
To free your stuck CD drawl, get a large paper clip. Straiten out one side of it. There is a small hole near the CD open button. Keep the paper clip as strait as possible & slide it into that hole. When it stops give it a harder push. That should release it. Remove the paper clip & either push it shut or try the open/close button
Posted on Feb 22, 2008
SOURCE: nu cdrw/dvd dbw-521 draw opens and closes repeatedly
Hello!
This sounds mostly like you got a Virus in your system, please make sure you got a good one like or Antispyware....
If you are familiar with windows services and startup Items you can find the one that is infected.
Let me know...
Posted on Dec 14, 2008
SOURCE: dvd not closing
The tray for the dvd player runs along a track that is moved by gears. Something is obstructing the gears or motor that turns them thus your tray and door will not close all the way.
Best thing I can suggest is to buy a new one as having it repaired will not be worth the effort financially. Seeing as it is messed up you can play with it a little more in hopes it may get back on track and start working again.
Note: from personal experience the more you try and force it the worse the problem will become (Burn out the motor, damage the gears further).
Thank you for choosing Fixya!
Posted on May 19, 2009
Obertelli
  • 3006 Answers
SOURCE: HEY i need to know if i can used a mini dvd in my
No. They're totally different.
Posted on Oct 06, 2010
My cd tray wont stay closed. it opens a few secons after i close it.
Don't worry dear user this problem is creates when we using a long time are cd/dvd writer but if have this type problem please reinstall your cd/dvd driver and your problem can be solved........
Jul 04, 2011 | Dell Studio 15 Laptop
Sir i am using acer 4736z i got problem with my dvd driver when i am inserting blank dvd for writing operation it shwos 0 bytes used free sapce 0 bytes not able to write data so what to do pls help me...
you have to make sure you are using the correct format for your drive i.e (+/-)
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 8X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM, 4X BD-ROM, 4X BD-R, 2X BD-RE, 4X BD-ROM DL (double-layer), 4X BD-R DL (double-layer), 2X BD-RE DL (double-layer)
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM, 4X DVD+R DL (double-layer), 4X DVD-R DL (double-layer)
8X DVD-Super Multi double-layer drive:
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 24X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
Apr 09, 2011 | Acer Computers & Internet
Opening automatically the drive..
check if something fell inside the drive..
Dec 18, 2009 | Panasonic (SW9585C) DVD±RW Dual Layer...
My cd compartment won't open.
You can manually open the door using a straightened paper clip inserted into a small hole in the door. Press firmly and the door will be released. You may have a CD stuck in there, or you may need to reinstall the driver for the CD. Or the CD drive may have failed...at least the control part that opens and closes the door.
Nov 12, 2009 | Dell Vostro 200 Mini Tower With 20" Flat...
CD/ROM Door automatically pops open, and then repeats after it is closed. Sometimes seem to be triggered by opening a random program.
sir
it is due to a virus called odiya or odissey in ur computer..i will advise you to install a good antivirus on ur computer and perform a full system scan
thankyou for using fixya
hv a nice day
dont forget to rate the solution
Mar 25, 2009 | LG GWA-4082N DVD RW Dual Layer Burner
Jensen vm9022 Disable touch screen???
try reentering the code. if not the screen whent out. i bought one of thees screens. and had to return it more than 4 times the screen whent out . cd player didnt work .ect.....ect...
Mar 07, 2009 | Jensen VM9710DTS DVD/CD/MP3/WMA 7"...
The dvd cd is not playing in pc but it is playing in handicam
have u closed the session in handy cam options kindly close the session and try again if ti works pls let me know i can provide another way round if it didnt help
Feb 03, 2009 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Stuck on Standby
Do a hard reset. Unplug it from the socket, the DVD and leave disconnected for 4 hours. This may or may not help, but it is a necessary step to restore all internal software codes to their factory settings.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 28, 2008 | JVC XV-523 DVD Player
Epson stylus r300
Hi Chillyslade,
Try this..
Close the CD/DVD guide, then press the font28.gif maintenance button.
If the CD/DVD tray is inserted, remove the CD/DVD tray, then close the CD/DVD guide
Hope this works, kindly let me know by providing your valuable rating.
Thanks,
Robosoft.
Jan 04, 2008 | Epson Stylus Photo R300 InkJet Printer
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
