SOURCE: icemaker will not dump the ice into tray
Make sure that an ice cude is not stuck somewhere in the maker. I had a simular problem and that was it.
SOURCE: frigidaire not dumping the ice
Hi: Dumping the ice is the start of the ice making timer. Before you replace the ice maker... Set the freezer one setting colder. The ice maker wont make ice if the freezer is not at zero degrees F. Just because things are frozen in it dosn't mean it is at zero. This happens a lot in the summertime. After resetting the temp don't open the door every hour to see if it makes ice as you will just dump the cold air out. Listen for the ice to dump, give it 24hrs. I hope this helps, Jeff
SOURCE: ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
SOURCE: Ice cube dispenser not working
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
