SOURCE: can't access internet wireles router says connected hp is a vista
If Nothing else changed in the last 2 weeks, such as a new router, or other hardware changes, AND it just started happening, I suggest you do a "system restore" to a date BEFORE the problem started.
This should correct the problem, and if you did any updates or other software installations, you will need to re install them.
Finally, one option prior to system restoring is to turn off the wireless router (unplug it) and then wait a minute. Plug back in. Then turn on your computer. You can try this first if you haven't already..
Good luck..
SOURCE: I just arrived home with a new dell laptop and
Hello
The setting of the browser has been disturbed by any mean, virus could be possibility. You can try to set default values and re-start browser,
otherwise
try to upgrade browser, download new browser and install from Microsoft or try some other browser like Google Chrome, firfox or opera
Good Luck
Do Rate the solution if got help
SOURCE: I have a BWA611SB wireless router, connected to a
All routers will have a tiny Reset button somewhere on them, you will need a small pin to press the button, hold it in for a few seconds, then restart the router, this will restore the router to factory default settings, there will be a password on it still, but it will be the default user name and password that was there when you first purchased the router, if you do not remember what it was, it will be listed in your routers manual. If you no longer have the manual you can check the manufactures website, most will provide a PDF copy of your manual that you can download.
Be advised, that as well as resetting your routers user name and password, it will also reset all other settings for your internet connection, and you will have to reconfigure your router to restore internet connectivity.
hope this was helpful, get back to me with the model and brand name of your router if you are unable to locate your manual and i can try to find a link to the PDF copy for you.
SOURCE: farmvill won't load on facebook keeps saying error 118
You probably have a virus or malware infestation. Run your antivirus software and download a copy of Malwarebytes anti-malware it's FREE and you can get it from here:
http://majorgeeks.com/download.php?det=5756
SOURCE: Bouncing balls won't load on. Facebook
Call Zynga's Phone#: 800-762-2530
How to reach a live person: Dial 3 when recording begins
