Question about Watches
Broken case lugs that hold strap pins broken
  • Sophia Chamberlain
    Sophia Chamberlain May 21, 2019
    my classmate mAkes $84/hr on the computer. She hAs been fired from work for 5 months but lAst month her pAyment wAs $7000 just working on the computer for A few hours. here's the site to reAd more--->> jobscycle.com
    Top Expert:
  • Watches Master
  • 25,011 Answers
New watch time
Posted on May 19, 2019
5 Suggested Answers
SOURCE:
SOURCE: broken strap.
What about checking whith an authorized retailer and buying them?
Posted on Aug 01, 2007
  • 40 Answers
SOURCE: My DKYN is a ladies
sounds like a broken spring bar.They break all the time and can be replaced by any good jewellery store while you wait.
Posted on Aug 19, 2010
SOURCE: I have a Pulsar watch Series PF3(Cat.7T62).The pin
PF3
Posted on Nov 18, 2010
  • 2501 Answers
SOURCE: hi,how can i remove the
With some practice you can get them out without damaging them.
With one finger press the pin upwards and use a small screw driver and
gently press the pin toward the center.
Relax the finger pressure while pushing with the screwdriver and then
return the pressure as you stop pushing with the screwdriver.
Some skill is required but you should be able to remove the pins after a few
attempts.
Putting the pins back in by reversing the process (i.e. put one end in
and press the pin gently onto the watch; push the spring loaded pin in
while pressing it against the case and when the pin is far enough in,
it will slide down the inner face into the hole.
Its easy! (after some practice!).
Posted on Apr 12, 2011
How do I take the leather strap off my bensherman wristwatch?
Depending on the model, if it is one that has a leather strap, then they are held in place with spring-bars that go through the ends of the band protruding out of each end. the points then insert into holes in the bezel lugs and thus hold the band in place.
The best method is using a tool made for this which you can pickup at any Harbor Fright Tools store if there is one in your area. Alternatively, use a small screwdriver and insert it against the inside of the lug where the band rides against. As you begin to pry downward away from the lug, you will see the spring-bar. Look for any ridges on the bar that can be used to pry further... it's really trial and error and use caution to not damage your band. another way that works quite well is a not-too-sharp knife. Again insert it between the band edge and the inside of the case lug and with pressure against the pin, pry downward away from the lug... the ping should disengage
Dec 05, 2014 | Watches
Invicta watch instructions
Straps are usually held in place by two spring loaded metal pins between the two lugs on either side of the strap. Look at the ends near the lugs you should be able to see them, use a very small flate blade srewdriver to pull back on the pin and once you get it, it will pop out of the hole its in.
Aug 18, 2014 | Invicta 15997 Mens Venom Chronograph Blue...
I have a fake chanel watch but can,t undo it to take it off..
You will probably need an assistant to remove your watch.
If you still can't get the watch off, let your assistant use a small screwdriver to remove the spring loaded pin that holds the strap to the lug of your watch.
( This can be done by putting a small tension on the strap pressing the screwdriver against the pin and pushing it in the desired direction. Some practice may be required!
Jan 07, 2011 | Bulova Watch
My DKYN is a ladies large D shape stainless steel case quartz. White leather strap. I have lost the tiny pin head that holds the strap pin in any suggestions please
Aug 17, 2010 | Watches
DON'T KNOW HOW TO FIT NEW WATCH STRAP WITH PINS IN. HOW TO UNDO ETC.,
Get pen knife and insert the blade between the watch strap and watch lug from the bottom side. Pry the springbar inwards using lever action. This must release the springbar.
Rate me, please.
Jul 31, 2009 | Watches
Kenneth Cole Watch 3574 pin in length has broken
are you talking about the band pins or the lug pins? most watch repair stations will have lugs and pins, and will replace for about $5...any more and you will be getting ripped off. Lug pins are a pain and unless you have the proper lug tools, you can end up scratching the finish of the watch...be careful!
Jul 06, 2009 | Kenneth Cole KC1169 Wrist Watch
How to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
Feb 10, 2009 | Nixon Scout NIX0013 Wrist Watch
Leather watch bands are broken
The "gizmo" would be the pin that attaches the watch to the case. You can easily purchase a replacement pin or strap at any store that has watches (even Wal-Mart). These are very inexpensive and each one will cost you less than $10.
Jan 03, 2009 | Fossil AM3695 Wrist Watch
Change ******** Anne Klein watch
Your watch comes with interchangeable bezels, not faces. Bezel is a ring or rectangle (depends what shape your watch has) surrounding a glass.
All bezels are mostly friction fitted,so, to remove your bezel you need to use a strong knife blade and press it between the bezel and the case. The bezel should lift up.
To get the bezel back you have to press it into place.
For changing the strap you have to turn watch upside down and using the knife or lug tool try to squeeze sprigbar end out of the watch lug. Sprinbar is the piece which holds a strap attached to watch. The end of springbar you will find exactly where the strap is attached to watch. Push it inwards and it must come out. The rest is like 2x2.
Good luck.
Dec 19, 2008 | Timex 1440 Nylon watch
Can't set the time or adjust the ******** crystal Starck PH-1100
Take a VERY close look at yor watch and you should notice a few tiny buttons. One of them should correspond to MODE, another to SET and so on- depends on how many your watch has.
Use a pin or a needle to push them and find out the settings procedure.
If you cant find buttons on the case sides, examine case back. They can be hidden between the lugs, so, the strap should be taken off.
Remember- there are no watches in existance without adjustment features. Even atomic clock needs to be adjusted after a few million years of work:))
Good luck.
Arthur
Dec 16, 2008 | Fossil Watches
Watches Logo
49 people viewed this question
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
