Https://www.briggsandstratton.com/eu/en_gb/support/faqs/browse/valve-repair-maintenance.html
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
Don't get too hung up on the exact valve clearance... 0.006" +-.001 is good enough. Not going to the moon, just mowing grass.
SOURCE: How do I replace the starter rope on a YArd
Thanks for your help, but my friend fixed it today.
SOURCE: I have a yard machine
Your carbs main jet is blocked. Using the primer supplements the fuel input and keeps the engine from becoming fuel starved.
You need to remove the main jet and run a strand of fine wire through the jet to clear it.
SOURCE: what type of oil is used in a yard machine lawn
SAE 30WT i.e non detergent. Change oil every 25 hours and every 4th oil change us a detergent 30 WT oil.
The manuals will never tell you that but having worked on small engines since the mid 60's that 4th oil change with a detergent oil does a bang up job of keeping the oil ring from eventually cooking onto the piston. Also washes out the crank case and makes it look like new!
Kelly
SOURCE: I have a Yard Machine
How old is this lawn mower, and have you replaced the spark plug recently?
Also, check to make sure the air filter is not clogged, preventing the engine from breathing.
SOURCE: My Yard Machine 11A-41MB029 lawnmower will not
Hi navydavy2001...
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel and not run properly.
NOTE: Before you disassemble the carburetor:
Make sure you mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard.
When you clean your carburetor I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
