This is the 2nd remote that has done this in the last 2 months
SOURCE: setting up 2nd wii remote
Greetings mlsaenz7,
You need to resynch the second remote to the Wii console. To accomplish this you need to hit the sync button under the battery cover on the remote, and then when the lights are flashing on the remote, you hit the sync button on the Wii. The synch button is located under the small cover to the left of the cd/dvd slot.
Thank you,
Dort
Go Ahead. Use Us.
SOURCE: 2nd wii remote & nunchuk won't work
well on the front of the wii where you put the sd card there is a red button next to the slot push that then the red button in the back of the wii remote with the battery cover open. its called syncing the wii remote to the system and it should help ya cheers
SOURCE: i have the viper 5900 installed in my 05 mustang.
replace the remote battery and reprogram the remote the problem on that kind of remotes is that the battery goes down quickly.
SOURCE: 05 Dakota remote wont work
I had the same problem. Is it a "Karr" remote? If so, I think they use really cheap switches. What I did to fix this is opened it up, de-soldered the switch from the trunk release circuit, de-soldered the broken switch from arm/disarm circuit, and replaced it with the working switch. Works perfectly. If you don't own a soldering iron, I suggest you buy a new one or buy a better alarm system.
