Hello Sandy, for what you say, it is very likely that the system that raises and lowers the arm is hardened or locked
It would have to disarm and clean the mechanism
I do not suggest you do so, contact a specialized technical service
I hope I can solve the problem
Greetings Franco Dosil
Hola Sandy, por lo que cuentas, es muy probable que se encuentre endurecido o trabado el sistema que sube y baja el brazo
Habria desarmar y hacer una limpieza al mecanismo
No le sugiero que lo haga, pongase en contacto con un servicio tecnico especializado
Espero pueda resolver el problema
Saludos Franco Dosil
https://www.vinylengine.com/library/yamaha/p-550.shtml
SOURCE: Optimus lab 1100 Turntable won't turn!
The mechanics in your arm postion is throwing the switch. A mechanical postion switch has sliped out of postion, a arm from the toner arm post has moved to an encorrect postion, or if your turntable has a multi-album play abilty your 'next to play record' post postion sensor switch is out of postion. Last or first is your belt could fool ya. Your belt may have a weak spot on it in turn no friction underload.
SOURCE: B&O Beogram 2000 turntable arm won't go down
Check to see if there is a cueing lever that is holding the arm in the up position. If no cueing lever and it has worked recently then something has happened to the changer mechanism. Open the bottom and look to see if there is an obvious problem like something stuck or broken. You may be able to make the mechanism go through its cycle slowly by rotating the platter with your hand so you can see where it is getting stuck.
SOURCE: Digitech turntable - skipping stylus and arm
You might need to apply more pressure to the stylus. There should be a weight on the end of the arm, it should have a control to move it up and down. The only other thing is the stylus damaged from transit?
SOURCE: I have a Denon DP-51F turntable. It was fine the
Hi, it has seized from lack of use. Disassemble and lube it. [email protected]
SOURCE: I have new Prolectrix turntable
I have the same problem and i can't find this black-head screw.
can you help thanks.
