Question about Health & Beauty
Error message my Permobil M3 power wheelchair. Message reads: "JSM bad cable 7F00". What do I do?
SOURCE:
SOURCE: error message
disconnect power from printer for 30 seconds. Hold down # and 6 at same time when you plug it back in.
Posted on Feb 23, 2008
likha
  • 790 Answers
Hi the wiring is not fit to your unit! please check one by one to see its fit
Thanks!
Posted on Jul 19, 2008
SOURCE: Panasonic FP 7742 Copier
check drum and drum sensor. if the Drum cleaning blade (DCB) has failed and is smearing toner around the drum then the drum sensor can't see the drum. clean it with a brush. the sensor sits in the drum/ cleaning station.
Posted on Nov 05, 2008
  • 3 Answers
SOURCE: error message power cable not connected to video card G manual
Power off your pc eject all cable then plugin again, if still not working try to change new cable. Some problem, video card not full insert.
Posted on Apr 12, 2009
MSG-CPC
  • 1325 Answers
SOURCE: Getting error code 2200 on Lexmark P6250 Photo
hi
here is what i have found -- follow to all instructions accordingly
although its for another model, these isntructions apply according t their techsupport i spoke with
.Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2.
Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3.
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4.
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
here is where i found the error http://support.lexmark.com/index?page=answers&startover=y&locale=en&userlocale=EN_US&question=2200 error#1
hope this helps -- God's speed
Posted on Nov 15, 2010
Permobil c 500 remote plus esp programming power wheel chair
A servicing dealer has to program the chair. Permobil C500 Corpus Power Wheelchairs USA Techguide A lot of people have had problems with this chair.
Jul 28, 2017 | Cars & Trucks
What battery is used in a Permobil C500 wheelchair
google model and battery. you should get many hits and many trying to sell you the battery.
Feb 28, 2015 | Health & Beauty
Permobil C 300 joystick showing joystick error and code 0E00 how to correct?
0E00 Joystick Error Joystick Error Right System fault Joystick Error
that is the info from permobil documents, it may be an error of the right motor / wiring "check all connections, unplug and plug in again all connectors, if still persists then it would seem to be an error with the controller its self, this maybe the pcb or the joystick its self, some times if you give the joystick a good workout (moving it to its limits over and over again for a couple of mins and then turn on and see if error clears) if that fails then it looks like a new joystick or the whole controller might need replacing, if you know some one with the same controller on there chair see if they will let you plug it in to your chair just to confirm it is that.
hope that helps, and if so please click "Helpful" to let others know
have a great xmas all
Dec 01, 2014 | Health & Beauty
Permobil chair
Maybe the gears or belts or whatever it runs with are not meshing properly or one of the belts came loose
Aug 24, 2014 | Health & Beauty
Hello, my name is JOSE and I live in Venezuela (Latin America), my daugther has a Koala wheelchair and today she crashed it into a wall in our house, the chair continued to move for a few seconds but...
In my experience with Permobil Power wheelchairs over 28 years you will get the best advice by contacting the service tech at the following location for help over the phone.
Argentina
Outlandish SRL
Conesa 1041,
(1426) Buenos Aires, Argentina.
Tel: +54 11 4553 8288
Fax: +54 11 4551 7557
gustavo.wright@outlandish.com.ar
Oct 08, 2010 | RTO Permobil Chairman Entra - Used...
Green power button flashing and wheelchair stops
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Sep 02, 2010 | RTO Permobil Chairman Entra - Used...
Is there maintenance manual?
mcdevito75 here, You can chek online at the wheel chairs name plus .com or, chek at any surgical supply outlet in your area for help.
Jun 24, 2010 | RTO Permobil Chairman Entra - Used...
Health & Beauty Logo
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
