If your fridge is set at the right temperature the corned beef should be fine - use your eyes and nose to test for unusual colour and unpleasant odour.
It is easy to be swayed because you simply don't fancy it and in that case it is probably better not to use it as sandwich filling or part of a cold collation but instead make a hot dish - such as a corned beef hash; piping hot it is an excellent dish for high tea and a safe way to use leftovers, etc.
There are many variations of the basic hash recipe; I prefer to use peas over sweetcorn though both go well together and leftover cooked cabbage, brussels sprouts, etc. can also be added. I also prefer to coat the diced corned beef with beaten egg before adding it to the potatoes.
Leftover potatoes and greens fried together until crisped underneath made a typical "quick" Saturday (winter warmer) lunch in many British homes and was known by the unappetising name of "bubble and squeak". Served with a fried egg, a couple of rashers of bacon and/or sausages, baked beans and either ketchup or hot brown sauce...
SOURCE: I cannot change the date on the Royal Time Master TC 100.
Open the cover. Note the three buttons: MODE, SELECT, and SETTING. To set the date, press MODE. The hour will blink. Press SETTING until the correct hour (a.m. or p.m.) is displayed. Press SELECT to actually set the hour shown.
Then the minutes will blink. Press SETTING until the correct minutes are shown. Press SELECT to set the minutes.
Then the seconds will blink. If you want to set them, press the SETTING button to set the seconds at 00 and press SELECT again.
The Year will blink. Press SETTING untill the right year is shown. Then, press SELECT to set the year.
The Month will blink. Press SETTING until you get the proper month. Then press SELECT to set the month.
Finally, day blinks. Press SETTING until the right day is shown and press SELECT to set the day.
That's it. You've reset your time clock. Good luck.
SOURCE: Do I need the rack in the pressure cooker to cook
Yes, you should put the rack in the pressure cooker when you cook corned beef.
SOURCE: rival roaster pan cooking instructions for corn beef
The Rival site has good cooking instructions:
http://www.rivalproducts.com/help.aspx?helpNav=1
SOURCE: My toshiba dvd recorder thinks today (1st MArch)
Try unplugging it and replugging it back in.
SOURCE: I've lost my recipe book which had the best corned
is this the one?
Tangy Corned Beef and Cabbage Stew
You don't have to be Irish to enjoy this lovely dinner.
Makes 6 to 8 servings.
Here is the link to recipes:
Thanks
Please rate FIXYA
Testimonial: "Thanks Urban Cowboy. This is the one! Appreciate your quick response. "
