Question about Samsung Televison & Video
Hi, I have a samsung un65ku6290 and am noticing dark spots all over the screen.
Recently, the picture was flashing blank but has stopped. Now I'm noticing dark spots all over the screen. I opened it up and all led backlights are functioning properly, diffuser panels are very clean and I don't see any physical issues. Could my panel be bad? or is it possible that the main board is the issue? Thanks
SOURCE:
budmrtn
  • 11361 Answers
SOURCE: Screen goes blank randomly during use while VGA
Yes, it can be inverter back lights circuits issue or bad caps in the power supply, worst case will be the lamps. Open it up and post back what you see inside so we can guide you further, see failed monitrs due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 22, 2010
  • 293 Answers
SOURCE: Samsung led TV un60es8000 dark blotchy area on the upper right of screen. Most noticeable on greys,blues and blacks. The picture attached is the color most responsive to this issue (dark grey). Light
This is caused by one of two things; a bad LED grouping (most common cause) either because the LEDs are bad or the power distributor fuse is blown and the group isn't getting power from the power supply unit. Or two: bad pixel group. But I'd check your backlight power supply for bad connections, blown fuses, or check your led groups for bad leds.
Posted on Jan 28, 2015
gopakumarg43
  • 76060 Answers
SOURCE: Samsung led tv - turns on,audio ok, no video, backlight on
Sounds like T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Oct 31, 2015
Testimonial: "I have already replaced T-con board. here is what happens. initial tv had blank screen , with audio. and back light on. so I ordered T-con board and replaced it but now with new T-con board connected backlight is flickering like a strobe light. and I have tried with 2 different lvds cables. same result of flickering."
  • 2940 Answers
SOURCE: power supply or main board ? RCA flat screen
At a guess, main board. I agree if power supply board is bad, you won't get DVD working.
Posted on Dec 31, 2015
gopakumarg43
  • 76060 Answers
SOURCE: I have the oCosmo CE4001. No picture. Just audio. No backlights. I can see a picture when I hold a flashlight up to the screen. Is this the LED driver gone bad? Is that part of the main power supply?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Oct 20, 2016
Thin blue line on all pictures
Try resetting the electronics to factory defaults. Re the flash - if it continues to stick get it open and leave it like that until you find out just what it is that is causing it to stick. Mechanical issue and do able.
Sep 21, 2017 | Nikon COOLPIX S8000 Digital Camera
Blue spot on my hitachi 50"rear projection tv model 2006 50vs69a
Do you have a center speaker near it? maybe move it, that is what I have done and it seems to have gotten better.
Jun 09, 2009 | Hitachi 50VS69 50" Projection HDTV
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Light spots
broken colour wheel is what the problem is.
May 26, 2008 | Optoma MovieTime DV10 Multimedia Projector
Samsung LCD Question
The model is a LN-S4041D. A 40 inch LCD. I can send you a photo but I can't get the file size small enough to post
Feb 09, 2008 | Televison & Video
Dark spot in centre of screen.
I have a little dark spot that i noticed it today too on my canon SD870IS i hope somebody can tell us what's the problem
Jan 02, 2008 | Olympus Stylus 700 / 700 Digital Camera
Dark spot on the top of the screen
May you should have a replacement for that, seems is has a factory damage on it!
Apr 05, 2007 | Philips 51PW9303 51" Rear Projection...
Televison & Video Logo
35 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
