SOURCE: Refrigerator malfunction
samsung units have duel cooling. that means there is a evaporator in the freezer and the fresh food section. it is possible that the temp sensor in the refrigerator section could be bad. and they have been known to have defrost problems there to. the samsung is a complicated unit and its hard to describe how to repair since there is a lot of electronics that control everything. the best thing I could say is to unplug the refrigerator for a few minuets. sometimes this will reset everything and start the unit back to the factory settings. if that does not work I would call for service. hope it helped you some
SOURCE: Fridge Temperature wont stop blinking
I had the same prob, you need to defrost it until No MORE water drips out of the drain pipes located at the back ( there should be 2 of them one for fridge one for the frezzer, make sure the rubber thing at the top of the pipe is not closed up- if it is cut it open ) when you think its defrosted place a cup under these pipes and leave it for a few more hours, if there is ANY more water in there your not defrosted yet and it wont work--- Leave the doors open of course, mine took almost three days and i live in a hot climate.
ok once you have done that, take the cover off for the main circuit board ( top of the fridge ) on the circuit board there should be a little black button with "test" on it hold that in and turn the fridge on. it should beep at you ( wait 5 sec ) then push it again ( beeps again, wait 5 sec ) push it again, you have to do it about 3-4 time before it stops beeping, when its stopped, just leave it, it should start up after a couple a mins.
the fridge will take much longer to get cold so be patient, if you find it flashing again push that test button, i just played round with mine and it came right, good luck, because the only other way round the prob is to turn it off at the wall and turn it back on.
SOURCE: Freezer and Fresh food section at room temperature
Sir,
To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant.
I suggest you to contact the service authority.
Thanks for contacting Fixya.
SOURCE: Freezer compartment is OK, But refrigerator is
sounds like your thermostat may be bad . the thermostat senses the tempreture in the fresh food section and turns the ref. on and off as needed . do it yourself roughly 39-89 dollars if u hire a proffesional around 95.00- 165.oo depending on were u live and who u use.hope this helps
SOURCE: Freezer is always reporting an error.
The defrosting issue is normally due to a rear brd failure as this controls most of the appliance. Dependant on the model the F90% is normally indicating how much time is left on your water filter before it needs replacing.
I hope this helps
