Device name .. Mac20:10:05:05:8D:E2
SOURCE: tungsten e2 wi fi card
Does you phone have data services enable to use your cell phone as a modem?
Wi Fi isn't needed to do it all you need to is pair the devices and follow the bluetooth setup wizard to select your cell phone provider.
Make sure your phone can do this.
Disconnect Treo from charger, if connected.Remove the battery cover and then the battery.Press and hold the UP arrow button on the 5 way navigational key of the device.
While holding the UP arrow button, reinsert the battery.When the second screen named "Access Powered" appears, release the UP button.Then, the next screen will ask you to set the date and time. That finishes the process of Warm Reset.
