Question about Tools & Hardware - Others
Hyper tough rotary tool was working fine,i turned it off and 20 mins later try to turn it back on. Lights on speed flash and won't run at all?
SOURCE:
Deutsche
  • 17 Answers
SOURCE: Check engine & traction control lights on
It might be the water temperature sensor for the brain not reading the right temperature, causes wrong parametres in the warming up periode, and then the diagnostic lamp will show.
Posted on Jan 08, 2009
ladywinn
  • 5138 Answers
SOURCE: Just replaced lamp a week ago and tv worked fine
2 things will cause this Lamp is defective, or Fan to lamp quits running this will shut TV OFF, if the fan quits running while Lamp is on it is design to shut Lamp Off to prevent Damage to Lamp IF Fans are ok It will be the Ballast board It is what turns Lamp on.Look on E-Bay for Ballast board if it turns out thats what you need or call Encompasss Electronics 1-800-638-3328
Posted on Sep 19, 2009
SOURCE: new battery, starter, cables, runs fine days or
had a similar problem with with my 4runner.replaced most of the fuel and ignition systems with no luck.finally traced the problem to a bad connection between the main relay and the fuel pump.there's a wire harness connection between the back of the gas tank and rear axle.I just replaced it with a solid run from the fuel pump and the relay.haven't had any problems since.
Posted on Feb 09, 2010
SOURCE: my enV2 wont turn on
My phone wont turn on because it got to wet and i dont know what to do i put it in some rice....but i know i have to leave it alone but still if it isnt working now how is it gonna in a couple of hours??
Posted on Jan 24, 2011
FitzOriginal
  • 842 Answers
SOURCE: bosch classixx 1200 washing machine.
Before you investigate the fault, try unplugging the machine at the mains for 20 minutes. This MAY reset the problem and all will be well. If that fails, then read on:
The flashing lights are an error code. You will see that there are a series of rapid flashes followed by a pause and then the series of flashes will be repeated, this is the error code being displayed. If you count the number of flashes being given then you use that number to correspond to the fault code, for example, three flashes would be fault code 3.
Fault Code 1 notlit.gif notlit.gif lit.gif Door open after program has been startedThis error code may well not show up for a minute or so after you actually go to start the washing machine but the door can be closed and the program restarted.
If the error persists there may be a fault with the door locking mechanism or door latch.
Fault Code 2 notlit.gif lit.gif notlit.gif Water intake has failed
Error after more than 10 minutesa failure of the water inlet valve or the water supply itself has been cut off somehow. This can be due to the water valve or supply as stated but it may also be worth checking the filters in the fill valves to ensure that they are clear.
Fault Code 3 notlit.gif lit.gif lit.gif Heating time exceeds 105 minutesThis would ordinarily indicate a fault with the water heating element or, certainly, the water heating circuit as the washing machine is indicating that it has failed to reach temperature.
The error can be caused by faulty wiring, the heater as stated, low voltage or even a calcified heater has been known to generate this error code.
Fault Code 4 lit.gif notlit.gif notlit.gif Takes longer than 6 minutes to drain.Very often you will see this error if the filter is blocked or obstructed or the drain pump is jammed or faulty.
This error code can also be caused by the pressure sensor being blocked by overfoaming from overdosing detergent or using a poor quality detergent as well as a pressure switch or sensor failure.
When this error occurs the program is aborted as it is considered to be a "fatal error" without any attempt to drain the washing machine.
Fault Code 5 lit.gif notlit.gif lit.gif NTC thermistor open circuit or short circuit
Self explanatory really, either a faulty NTC or wiring. The washing machine will complete the program but will not heat.
Fault Code 6 lit.gif lit.gif notlit.gif Unexpected heatingThe machine has attempted to heat at a stage in the program where it should not.
Fault Code 7 lit.gif lit.gif lit.gif Fault detected in motor or drive circuit
Very often you will see this error if the carbon brushes or the motor fails.
This error code can be generated by no tacho reading from the motor (the electronics cannot see the tach generator of the motor), a triac fault or short circuit or a faulty reversing relay on the control board. The washing machine will try to start the motor but after several attempts the program will be aborted with this error code which is again consider to be a "fatal"
Posted on Jul 05, 2011
Flex shaft attachment won't work
find the little square attachment and place on the end of the dremel tool. I didid the same thing. Worked fine after I put the other part on.
Nov 06, 2012 | Dremel Variable - Speed Multipro Rotary...
I replaced my battery and the radio does not turn on nor do the head lights. All fuses are fine. The lights show if i want to flash the brights. But nothing steady. I even replaced a bulb with no change....
Well, I guess you won't be using the radio or driving after dark
You will get the code when you spend something,
because without the scan tool it won't happen.
Jun 10, 2011 | 1996 Hyundai Accent
Dremel will not turn on?
IF you don't release the bit lock, it won't run.
Aug 01, 2010 | Dremel 395 Variable Speed Multipro Rotary...
Crafatsman Rotary Tool Single speed - chuck has no power - that is motor will run smoothly - - chuck will turn - but your finger can stop it - it is free wheeling on it's own even while the motor is...
These are fairly easy to disassemble and get back together, take it apart and find out what got stripped, It might be an easy fix, then again, it might be going back to sears. They will take it back no matter what. Hope this helps.
May 29, 2010 | Craftsman Single Speed Rotary Tool
WON'T START
my 2006 pt cruiser won"t start. the light do come on but it will not turn over just a clicking sound. i drove it for about an hour then went back to it 30 mins later and it didn"t start. just clicking sound.
Sep 21, 2008 | 2006 Chrysler PT Cruiser
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
