Question about Philips Coffee Makers & Espresso Machines
Hello, I have automatic philips coffee machine and today it is showing an error code 2. It isnt available on the list of error codes on the manual. Anyone knows what it is or how it can be fixed?
SOURCE:
SOURCE: Electrolux Wall oven E30EW75ESS
Same F23. Resetting the beaker seems to fixed it. Thanks to all
Posted on Jun 07, 2008
SOURCE: error code 43 on F& P washing machine
The micro switch or the lever that activates it seems to have been the cause of the Error Code 43. Have re-seated the switch in its holder and ensured the activating (out of balance) lever is moving freely. The switch appears to be OK and now it is all re-assembled, the Error Code 43 is gone. Machine is operating normally again.
Out of Balance Switch was located below the right hand side of the computer board (module).
Rgdz John T
Posted on Sep 20, 2008
  • 215 Answers
SOURCE: copystar cs-2550 service code c6000
try this. enter "10871087" from keypad. you should now be in maintenance mode. enter "163"press "start or print" key. you should see a screen that says "execute" or it may say "reset". cursor or highlight "execute" and press "start" key. now press "stop/clear" once or twice. then press "01" then "start" to exit maint. mode. very important!! as soon as you press "01" and you see "please wait" open your front door. wait 2 secs, then close door. that should get you going unless there is a true failure. good luck and you may want to write this procedure down as it may happen sometime again.
hth,
razors
Posted on Mar 30, 2009
SOURCE: Universal Remote Control code for Strong STB
i need the code of strong reciver for remote control
Posted on Apr 11, 2010
SOURCE: Kenmore Elite Washing machine error codes
I am getting the code f 21 what does this mean
Posted on Jun 02, 2010
What does this error mean in the Class 9 Espresso EB5 USB coffee machin
Hello, Abdallh -
If you have the owner's manual for the machine, starting on Page 35 see the list of error codes and what they mean.
If you do not have the owner's manual, this is the link for it (PDF format, you will need Adobe Reader, which is free to open, download, and save the manual to your computer):
https://www.ranciliogroupna.com/filebin/images/Downloadables/User_Manuals/MAN_Classe9rev_AC_2.pdf
Note: There is no EB5 error code listed. Perhaps you mean error code E05, or error code E15.
Jan 03, 2018 | Coffee Makers & Espresso Machines
My Krups EA9000 and it shows error code 3. I brought this machine from UK to South Africa when I moved. People here who service Krups cannot find appropriate manual to fix this error code. Any ideas?
If the people in SA are authorised service agents they may need to contact the technical dept at Groupe SEB SA to get the info. It's not available online through the normal service centre channels.
Jul 28, 2017 | Krups Coffee Makers & Espresso Machines
Error code 5 on saeco minuto coffee machine
Error code 5 means the water flow is obstructed. Here are possible locations:
1- The machine was not descaled. Calcium deposits are clogging the water system.
2- The flow meter is not passing impulses for water flow speed & quantity.
3- Descale Descale Descale.
Before you select the automatic descaling, make a few espresso without adding coffee grounds. The automatic cycle does not clean the coffee side of the machine. You have to do it intentionally.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Dec 18, 2016 | Saeco Coffee Makers & Espresso Machines
My Krups XP 9000 showing "Service 2 contact hotline" Has anybody figured out how to fix it. Krups has been no help on this one they said they do not have a service manual on it. They never made one.
I think that error code means it needs a new motor driving unit for the brewing unit. Tell me what it does in detail when you attempt to make a coffee. screaming_skull@hotmail.com
Oct 03, 2013 | Krups Super Automatic XP 9000 Espresso...
My new gaggia accademia won't work. IT shows error code 05. Con Youtube help me?
reset the error code and read your instr. manual. God bless you
proceed according.
If the coffee maker doesn't work at all, make sure power is on at the outlet, check the electric cord , the internal fuse or the thermostat and heating elements replace as needed.
Oct 17, 2012 | Gaggia 10003380 Accademia Automatic...
Error code 07 on my Krups XP 7220 coffee machine
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
Oct 26, 2009 | Krups Small Appliances Espresso Machine
I have a new AT&T (Motorola) box and need to program my new Philips HTS3372D DVD/Theater system to it but none of the codes or automatic search recognize it.
Such a code may or may not exist. If none of the codes listed in your owners manual work (you didn't list a model number so I can't give you specifics)you have 3 options. 1) Contact GE and see if they have additional codes not listed in the manual. 2) Contact Philips and see if the have additional codes to try. 3) Purchase a 3rd party remote that works with both devices.
Jun 03, 2009 | Philips PM435S Remote Control
Machine Fault Error No 06 at start up Model is Krups XP7240 Expresso - not listed in product list
The error 06 (comes after start up) and machine in auto test - happens because more than one problem. One of the compulory services, rinsing, change water filter, cleaning OR / AND descaling is out of date. Start off with one at a time and do ALL.
Reconfirm it by going into "Product Information" and confirm that the cycles since previous cleaning, descaling and water filter replacement is ZERO.
Your machine will NOT have start up problems any longer
Regards
Jul 10, 2008 | Krups XP4030 Espresso Machine
Coffee Makers & Espresso Machines Logo
37 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Deanna Melroy
Deanna Melroy
Level 1 Expert
Pierre Laplante
Steve Allison
Steve Allison
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
