Question about Car Audio & Video
My magazine is stuck closed how do I get in there and open it
  • shaun hancock May 19, 2019
    Hi Heather Baker, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? IE model number/serial number of the device.
My 2000 Audi A6 CD changer doesn't eject the magazine and I also can't select different modes on the radio can you please assist me
  • The magazine will not eject if a CD is stuck in transit loading or unloading
  • Radio operation is disabled while the magazine is stuck
May 12, 2018 | Car Audio & Video
Why won't Easy Shot staples advance/shoot?
Hi Elaine, The EasyShot stapler is a bottom load stapler. Please follow the steps below to make sure you are loading the staples correctly.
- Turn the tool upside down so that you can read the text "use light duty narrow crown" on the bottom of the magazine
- Open the magazine of the tool
- Place the staples inside the channel (not on the back of the magazine rail)
- Close the magazine.
Attached is a picture so you can see where to place the staples.
If you are still having trouble please contact our customer service department and we can assist you further.
customercare@arrowfastener.com
Thanks
May 29, 2015 | Staples Tools & Hardware - Others
How do i install cartraige in to my sks
Pull the bolt back far enough that it locks open on the empty magazine. Push cartridges down into the magazine and then pull the bolt back and let it snap closed to chamber a round.
May 19, 2014 | SKS Rifle High-profile See-thru Scope...
Stuck CD Magazine
You'll have to take the cover off. Look for screws around the back and on the sides. Most likely a cd is wedged in the wrong place. (not fully ejected) and is preventing the magazine from ejecting.
Jan 02, 2014 | Fisher Audio Players & Recorders
Saab cd changer
You may have a CD stuck between the player mechanism and the magazine. You can try loading and unloading several times to correct the problem but eventually you may have to resort to disassembly to get the CD back into the magazine
Oct 24, 2012 | Honda Auto Changer Board
I can't remove the left magazine from a Superloader 3. The unit has failed and I need to remove the tapes. The eject magazine does not work, it doesn't pull the drive gear back.
I found this solution on line and it worked for me. Believe it or not I used a butter knife and stuck it between the magazine and mail slot close to the bottom. You will hear a click and the magazine will pop out. It is like using a paperclip for a stuck CD. Make sure you power the device down and unplug it.
Oct 01, 2010 | Quantum SuperLoader 3 LTO-3 Tape Drive
How do you load a 12 gauge pump action Mossberg (500)? There is no magazine for it, but, is mag ready. How do you manually load?
The loading port is on the bottom of the reciever. You mention that it is "magazine ready"? Mossberg shotguns have a tublular magazine underneath the barrel, surrounded by the action bar and front grip.
Loading the magazine entails holding the shotgun in one hand, taking the shell in the other with the folded end facing the front end of the barrel. Place the shell in the magazine opening (on the bottom) and push it up with your fingers and forward with the thumb of the same hand. It will go completely forward of the silver/blue lifter and stay there when you let go. (the action must be closed to load the magazine).
Alternately, you can open the action and pop a shell into the ejection port on the right side, close it back up, and shoot!
Sep 17, 2010 | Mossberg Optics
How do you close the magazine on a bostitch sx150
once the nails are in place, slide the slide forward and you may have to press in the same button you use to open the magazine to get it closed the rest of the way.
Dec 05, 2009 | Stanley Factory Reconditioned Bostitch...
Bose Lifestyle 30 6-cd changer magazine manual release?
hi, you can release the magazine by inserting a small flat head screwdriver in the slot and pushing the lever towards the back of the unit, this will release the cd but only if ther is not one stuck in the player as it will remain halfway between the mag and the cdplayer. don't force it to comae out. remember to obviously have the dorr to the player open before you try this.
Jul 29, 2007 | Bose Lifestyle 30 System
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
