SOURCE: am reception
I've used this radio for years. It's a direct replacement for Porsche cars up to about 1998. Installation is easy and make sure to get the iPod connection cable. It's an assessory.
About AM yes there's the 9kHz vs 10KHz, but frankly here in LA it gets better AM reception than the JBL in my new Prius. The only problem is you can't buy it in NA. Getting it from the EU is a pain. But it's worth it
SOURCE: my concert radio wont pick up AM stations
your probably in a bad place and you wont pick up a signal like if your out of cell phone range, except your probably out of radio range for am stations.
SOURCE: 97 mitsubishi bad radio reception
It sounds like you are just in a weak reception area. If you feel this is not the case first try replacing the entire antenna assembly, it would be the primary cause of this type of problem.
SOURCE: 2007 chevy radio weak signal. Iknow being out of range is not the problem.
it could be a loose antenna is juest come loose from the back of the radio the antenna is for long distant stations
