My Bernita upper thread keeps breaking
Likely tension too high or thread is snagging somewhere.
With machine threaded, test top thread feed and tension as follows.
Needle up, presser foot up, tension set to 4. Make a long slow steady pull of thread. The thread should advance smoothly and freely through needle eye. Any snagging or sudden change in tension is suspect. Make a couple more pulls to make sure thread doesn't snag while unwinding from spool. Note this is no tension as presser foot is up which opens tension plates.
Lower foot and make a couple more slow steady pulls. Thread should advance smoothly through the eye of needle. Note the change in tension with foot down.
If feed/tension tests ok, then could be problem with bobbin area, but I'd expect more symptoms, such as thread balling underneath when top thread breaks.
Whats your history with this machine?
