Question about Staples Tools & Hardware - Others
Senco staple gun skips staples - Staples Tools & Hardware - Others
SOURCE:
  • 55 Answers
SOURCE: Need help on how to put staples in Ace staple gun 22084
At the very botton of the stapeler in the back there should be a square mechanism press in and down then just slide the staples in and eplace the mechanism the way you took it out
Posted on Dec 05, 2008
comax
  • 154 Answers
SOURCE: Senco narrow crown Stapler Piston will not go back
There is a spring and piston in the back cap of the nailer, this must be free moving and not sticking. If it is sticking it will cause the problem you discribed. If that looks ok you probably should install an o-ring kit and that should solve the problem. A Senco service center will carry the proper parts.
Posted on Apr 16, 2009
tbirdfan1
  • 3051 Answers
SOURCE: reloading ace 22084 staple gun
Hello there:
when you purchase staples for this particular gun even though you might get a staple that is says it fits this gun you need to look at the type of staple if you get the one that says heavy duty it will not work it took me 2 times to find out the right ones for this gun it comes in a green box and says standard duty on it not heavy duty this is where most people make their mistake. ok?
best regards michael
Posted on Oct 03, 2009
rowdy45176
  • 2176 Answers
SOURCE: how do I get a part of a Senco model K staple gun
go to Senco.com and you can download a schematic and also order parts direct from them
Posted on Mar 19, 2010
  • 342 Answers
SOURCE: Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
Posted on Apr 05, 2010
What is wrong with my Senco pneumatic upholstery stapler?
only a guess but is the anvil sticking out the bottom where the staples come out . if so push it up a little with a flat blade screw driver .
Feb 23, 2015 | Senco Tools & Hardware - Others
Wount pull staples in for driver to drive the staple
spring is jammed somewhere. not pushing staples along.
Nov 04, 2014 | Tools & Hardware - Others
Need the diagram of the exploded view of my senco staple gun
without any other information I can't help, but you can go to senco.com and they have a section for downloads and manuals. You will need your complete model number and be sure to check in the older tool section if you can't find it. If you still have trouble get back with me with the tool information and I will check.
Aug 22, 2011 | Senco Tools & Hardware - Others
Air tends to leak near trigger of my senco sls15 1/4" crown stapler . how can i stop it?
You have worn or broken o-rings/seals inside the gun. You need a Senco repair kit YK0393. Senco doesn't make them any more but there are still a few to be found on the internet. If you can't find one, go to the Senco webpage, find the parts breakdown for your gun and order all of the o-rings, seals and gaskets and rebuild your gun.
Feb 09, 2011 | Senco Finishpro 15 Finish Nailer & Sls15...
After shooting a staple the driver does not return up into the stapler.
obvious answers are 1. a burr on the striker, 2. a bent striker. 3. a trapped staple 4. a broken return spring. other than that I cant help you without seeing it.
Feb 02, 2011 | Senco 300120n Sksl Medium Wire Staple Gun...
Do i need to buy piston driver assembly or can i by just the driver blade
These new Senco FinishPro tools are chinese made and unlike the old US made tools, you need to buy what's termed a 'piston driver unit'. It should be fairly cheap though, compared to old Senco parts.
Jan 17, 2011 | Senco Finishpro 15 Finish Nailer & Sls15...
Stapler will staple ok then it will jamb and break staple in half,and driver will stick but you can put driver back and will run for a short time then has same problem. It also is breaking up staples as it...
It sounds like the gun is working properly but is having feeding problems. First, make sure you are using the proper staples for your gun. Senco makes three versions of the SKS(XP) stapler: The SKS L11-17 drives 18 gauge, 1/4" staples. The SKS M12-17 drives 18 gauge, 3/8" staples. The SKS N12-17 drives 16 guage, 7/16" staples. None of them use staples over 1 1/2" long and each gun will only shoot the staples it is set up for. If you are using the correct staples make sure the rail and nose peices are clean and the feeder shoe and staples are riding freely on the rail and the feeder spring holds them firmly forward in the gun. Lastly check the tip of the driver to make sure it is square, it should not be rounded or have any chips out of it.
Dec 07, 2010 | Senco SKS 18 Gauge Stapler
I have an older model senco finish nailer that continuously blows air out the exhaust what is the problem?
probably a split or stuck o ring. You can go to Senco.com and download a breakdown and purchase a rebuild kit for this tool.
Mar 27, 2010 | Senco Finishpro 15 Finish Nailer & Sls15...
How do I get a part of a Senco model K staple gun
Mar 19, 2010 | Senco Tools & Hardware - Others
Tools & Hardware - Others Logo
50 people viewed this question
Top Staples Tools & Hardware - Others Experts
Jo Ann
Level 1 Expert
Van Allen II
Van Allen II
john h
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
