I am not sure that win 10 is supported by your printer but try this site to download scan drivers https://www.support.xerox.com/support/workcentre-pe114e/file-download/eneg.html?operatingSystem=winxp&fileLanguage=en_GB&contentId=49145&from=downloads&viewArchived=false
SOURCE: HP 3055 model scaner problem
Document feeder error means that the printer is expecting you to have a document in the ADF "automatic Document Feeder" on top. If you are having this on the laptop, go into the scanner set up on your laptop, and change the device from document feeder to flatbed. It should work fine. You can also mimic the settings from your desktop to your laptop.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: my dell a920 printer/scaner will not scan
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
SOURCE: lsu error in xerox pe114e printer
That is a last error. Most likely the motor that spins the mirrors has failed.
SOURCE: how to install Xerox WorkCentre PE16 scaner? i ...
How to install Xerox workcentre PE16 scaner?i install twin & driver but not work . Please help...
SOURCE: LaserJet CM1017 MFP scanning issues
Improve the Fixya.com experience for everyone by voting!
You are in luck because HP just released on 7/5/2011 a new driver for your CM1010 printer. The following is the description with the download link following.
Type:
Driver - Documentation
Version:
N/A (5 Jul 2011)
Operating System(s):
Microsoft Windows 7 (32-bit), Microsoft Windows 7 (64-bit),
Microsoft Windows Server 2003, Microsoft Windows Server 2003 64-Bit
Edition, Microsoft Windows Server 2008 W32, Microsoft Windows Server
2008 x64, Microsoft Windows Vista, Microsoft Windows Vista (64-bit),
Microsoft Windows XP, Microsoft Windows XP x64
File name:
HP_UPD_direct_IP_Printing.pdf
Download this driver by clicking on the following link: CLICK HERE
All the best
Ben
