Tzumi Sound Mates earbuds,,can only get one to work...did work at purchase.
SOURCE: Losing sound in my Shure ear buds, they are one year old.
the wire breaks after a while in ear buds ,and head phones due to the constant flexing,and moving.they probably need to be remade.by cutting out the bad part of the wire(usually close to the fitting)You can usually wiggle the wire and find where the breaks are that way.it can be a real pain re soldering ear buds.also check the plug end by wiggling the wire there.
SOURCE: Ipod (30 G) earbud jack only plays out of one ear
Try this;
Two findings from a quick research done ;
1.) The cord must be tightly pushed (locked) into the socket else it won't play.
2.) There are cases reported of a faulty jack with this series of Ipods.
SOURCE: The left earbud of my Bose in-ear headphones doesn't have sound
You probably need to replace the stereo plug on the end that goes into the jack. Most of them are molded on unfortunately but it can be done with a new jack and some soldering skills. There have been lots of people with the same problem on this site so there are already some good explanations of how to do this on here.
SOURCE: no sound coming out of right ear
Since these are just a month or so old, it is probably a warranty issue and should be able to resolved by the manufacturer - or in some cases by the store if they accept returns inside of the time you've own them.
If you no longer have the sales slip or are unable to provide documentation for warranty work, you might be able to make a repair your self if you can do some simple soldering. Locate to point on the cable where when disturbed, the sound cuts in and out. This is a likely point of a damaged or broken wire. Cut the cord just above the point of damage - closer to the ear buds. Use a meter or test light to determine which wire goes to which part of the old plug (you might have to cut the end of the cable a little shorter so that you are not trying to test through the broken wires). Buy a replacement plug that matches the original at a Radio Shack or similar type store and reconnect to match the original set up (as determined by the testing earlier) If it the ear bud cable is too short, you could purchase an extension cable that has a match plug on one end and jack on the other.
Of course you could always just cut the "bad part" of the cable out (an inch or two should probably do it) and reconnect and cover the wires in a method of your own choosing and be done, too.
