Cell Phones Logo
D
Dahir Issack Ibrahim Posted on May 18, 2019
How can i retrieve my kra pin - Cell Phones
1helpful
2answers
Kubota t1880 Reverse problem. Will go into reverse, but not when blades are engaged then it dies.
It's a feature.
... The KRA system incorporates an
override switch on the dash that allows the operator to
override the system and keep the PTO engaged
during reverse travel. ...
94 gmc 4.3 vin z 2wd standard 12 pin aldl connector code retrieval
I have an OBD-II and it plugs right in so can can retrieve codes.
My truck is a 1992 S15 w/4.3.
Can i get my lost mxit through my facebook
Greetings,
If you forget your PIN and need to request a new one, you need to ensure that your Mxit Profile is updated with your mobile number.
We will not send your PIN to you if your correct mobile number is not in your Mxit profile.
To update your Mxit profile with the correct mobile number please go to:
INFO> My Profile>Mobile.
There are currently 2 ways of retrieving your PIN.
1.Sending an SMS containing PIN and your Mxit ID to 34006
If however you have registered with a Mxit ID, you can retrieve the PIN by sending an SMS with the word PIN and your Mxit ID.
For example, the user mrgreen requests his PIN he will have to send the SMS containing only the following :
PIN mrgreen
If your Mxit ID is your phone number, please ensure that you enter it in international format.
Here is an example of what this SMS should look like:
Pin 27821234567
This still has to be done from the SIM that was used to register the Mxit profile.
Please note:
* This only works with cell numbers that are in South Africa.
* Please make sure that you send the SMS from the same cell phone number that you are registered to Mxit with. This is one of the reasons why you must have the SIM card for the Mxit profile that you are using.
* This SMS costs R2.00
2.Retrieving your PIN through email
If you have added an email address when registering, you can simply go to http://password.Mxit.com and fill in the details.
Your PIN will then be sent to the registered email address which you have entered enter.
Keep in mind that the email address must have been registered on your Mxit profile before the PIN was lost.
Please do not make the mistake of using your Mxit email address to retrieve your PIN.
If you do not have your PIN you cannot access your Mxit account, if you cannot login you will not be able to receive your mail.
Apr 06, 2014 • Cell Phones
Got a new battery in my kra and everything is working except the two time needles (hour and minute) is it broke?
If it was working OK before the battery was replaced, then it is unlikely that it should fail because you changed the battery.
Most electronic watches have an inscription "AC" on the chassis of the watch near the battery.
Instructions say that this point (or somewhere near it) should be connected to the case of the battery. Any metal implement will do e.g. a pair of tweezers would be ideal.
Althoughno maker seems to be willing to explain why you need to do this, I think that it resets the electronics.
1helpful
2answers
Scan for available TV stations - how to
azt szeretném meg tudni hogy a philips német menűs tvét hogyan kel be állitani magyar csatornákra
Forgot pin for 205 nuvi gps How do I retrieve Al
Go to the location which you would have set it as your security location. That way device would be able to confirm your identity as a owner without a pin.
--Sandy
Wii help
http://www.nintendo.com/consumer/systems/wii/en_na/settingsParentalControls.jsp
You will be prompted to select and answer a secret question that will allow you to retrieve a forgotten Parental Controls PIN. If you forget your PIN, please follow the prompts on screen to answer your secret question. If you are unable to retrieve your PIN by answering your secret question, please call Nintendo Consumer Service: 1-800-255-3700.
2helpful
DVD DRIVE DRIVER FOR ACER ASPIRE 3623
Generally you don't need the Optical drive driver. Windows XP has built in drivers to support them. If you tell the exact problem then may be we can help
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
