SOURCE: F0 error code on GE wall oven
I had the same FO error. It turned out that the ribbon cable from the front panel was not making good contact where it mated with the circuit board. Remove ribbon cable and clean contacts on ribbon cable. Replace cable and problem should resolve.
SOURCE: Hi All, My Voltas Split AC
in the pcb board there is a switch called manual switch it will on ur unit just open the indoor flap.
SOURCE: my ac voltas split.it does
Transmission problem. Check remote with mobile camera, by pressing any button. If ultra light flashes in camera, it's o.k. Even,you can try with another remote and confirm. If your remote is o.k, problem with indoor PCB. Replace or repair. Thanks and hope helpful.
SOURCE: voltas vetris prenium split ac - error display F2 on front panel
F4 error in voltas gemini splite ac
