Televison & Video Logo
m
michael smith Posted on May 18, 2019
Is there aerror code related to milaukee cordless brushless Sawzall working light when u pull trigger no power but light blinks 3 times in sucession
5 Related Answers
Anonymous
  • Posted on Dec 31, 2008
SOURCE: I have a 18V DeWalt
It depends on what you mean by intermittent. If the drill takes a few tries to turn on, but works fine once it does, it usually means there's a problem with the switch. If the power is weak and tends to cut out, it generally means there's a problem with the motor - usually brushes. This article might clear things up a bit:
Whodunnt? The brushes or the switch?
You can get whichever part you need replaced on that same site.
Anonymous
  • Posted on Apr 24, 2009
SOURCE: Kawasaki 19.2 cordless drill
Re: Burned trigger switch: call the number on the drill (800.590.3723) and tell them what happened. They will offer to send you a new switch or have you send the drill in for replacement of the switch--although the person I talked with said they would probably just replace the whole drill.
Craig Becker
  • 142 Answers
  • Posted on Dec 17, 2011
SOURCE: my dewalt cordless drill stopped working in the middle of drilling a hole. is the trigger faulty/broken?
First before you open the tool ground yourself. The switch is probably static sensitive. Now open the tool and check for wires that may have come loose from the switch, or motor brush area. If no bad wires make sure the switch terminals are ok (not broken or bent and are tight enough to make contact with the batery terminals). Next check the brushes and make sure they move freely in the brush holders. You didn't state the model so it may not have brushes you can access. If all that is good disconnect the motor from the switch and secure the motor in a vise. Take wires with alligator clips and connect the battery directly to the motor for just a second to see if it runs. If the motor runs you have a bad switch assuming your battery is charged.
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Aug 29, 2012
SOURCE: error code 13 on mitsubishi wd52628
wait for the light to go out then press power. Then if it doesnt power up hold the menu and the Device/input buttons on the set both in together for 5 seconds the light will blink a series of blinks pause briefly then blink another number of blinks then pause then it will repeat the same two digit blink sequence a few times . Let me know the two digit blink sequence.
Anonymous
  • Posted on Feb 12, 2013
SOURCE: My milwaukee 262020 18v sawzall suddenly stopped
This model has had problems with a slide block inside the gear box that breaks. (it has been re-designed) the broken part can get into the gears and lock it up. new part includes whole new housing for gear box, approx $35 for replacement part.
I have a brushless Hitachi sawzall why when I pull trigger nothing happens but Sparks are being thrown out where the battery goes?
DO NOT USE this sawzall. You will need to either strip it down again, clean and re-check EVERYTHING or take it to a specialist repairer.
Sparks are usually a sign of a serious short circuit in the electrics. When you took it apart you could have re-connected some of the wires incorrectly or accidentally gotten grease into the electrics. Get this repaired or replaced Before using it.
My Ryobi brushless impact driver suddenly won't start. The Led just blinks/flashes each time you pull on the trigger.
try pressing the direction switch. sometimes, if it's not fully pressed to forward or reverse, the drill will not operate.
We have a dewalt 20v max sawzall with a fully charged battery when you pull trigger it does not run only beeps?
is it brushless? if it has brushes make sure they move freely in their box otherwise the motor isn't getting power. if it's brushless either there's a connection problem with the smaller battery wires telling the saw each cells voltage or the motor controller is bad.
The 3 led lights wont go out on my brushless dewalt impact driver after ive pulled the trigger??
faulty trigger switch suggest to clean the inner part of switch or insulate seized wire or renew faulty trigger stitch
RILL IS BEAPING WHEN YOU PULL THE TRIGGER
Giving 2 short beaps and 2 red leds on it blinked .
If its a EY7440 ? the control pcb must be the problem itself , but if its a brushless model then the 6 mosfets on the motor could be short circuit EY754* was oft the cause, but they have modified the motor for the new EY75** models with brushless motors .
2answers
How to increase power to my daystate mk3 air rifle
Get a new air rifle with more power?
Dec 29, 2013 • Optics
My 18v lithum makita drill is starting to cut in and out
If impact makes a difference in how it runs, you have a bad contact somewhere. It could be where the battery connects to the switch in the handle, it could be the switch, or it could be one or both wires from the switch to the motor. It could be in the motor but it's unlikely as the brushless motors have very little to go wrong in them but they are manmade machines so it's a possibility. Makitas have a three year warranty on them and the brushless tools are a new line so it may be repairable by a service center for free.
Btd144 when pull trigger light flashes drill dont go
The battery itself has a deep discharge protection .
Or the electronic or the battery its a new
phenomenon where you can have bought electronica and a triggerswitch and you have measured the electric field on 0.3 ohm on both 2x3 coils and the battery measured on maybe 15 Volt and it do not give nothing yes the lamps burned , but there was not an charger in my case delivered so i am also waiting for this problem by a Makita Jigsaw because a colleague has allready a electronic circuit and switch ordered and tried with that battery and an other battery but no life at all, so a new battery should may be working. or a broken or new damaged electronic part was delivered. that brushless tools are a young technical thing, many brands have.
the teething problems out, by the switches and the power mosnfets(panasonic) Makita is new for me this comparable problem a have also have yesterday.
next week i know more about a possible solution.
Makita BTD144 Lithium Ion Impact Driver Brushless Motor Parts
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
