Dehumidifiers Logo
Cindy Coffin Posted on May 18, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bought a used classic r410a dehumidifier but no manuel. Is there a printable users manual i can access?
Terry
Level 3:
  • Master 11,377 Answers
  • Posted on May 18, 2019
Terry
Master
Level 3:
Answers
11377
Questions
Helped
4619843
Points
152765
2 Related Answers
Anonymous
  • 10 Answers
  • Posted on Oct 23, 2010
SOURCE: I have a DANBY PREMIERE
On the control panel the 3rd button from the left is the timer button. If you press this button when the unit is running the number display on the left will start blinking- use the up/down arrows to set the time that you want the unit to run.
If you press the timer button when the unit is off it will run on and off for the designated time you set- eg if you set 1 then every 1 hour the machine will switch on and run for 1 hour.
(The left # will just blink once you have the time you want just leave it and eventually the normal humidity setting reading will show)
D. E. Hev
  • 1187 Answers
  • Posted on May 04, 2015
SOURCE: Where could I get an owner manual for Danby Premiere R410A dehumidifier ?
http://www.danby.com/en/US/our_products/dehumidifiers/list?f1=8 Dehumidifiers Large Dehumidifiers
How do I get a user Manuel got Ebac880 dehumidifier
http://www.produktinfo.conrad.com/datenblaetter/525000-549999/531001-an-01-en-Luftentfeuchter_Modell_660.pdf
1helpful
DANBY PREMIERE DEHUMIDIFIER R410A OWNERS MANUAL
I have 70 pint premiere dehumidifier , and it's not producing any water . What should I do ?
2answers
2helpful
What is the proper setting for Danby R410A?
R410A is refrigerant gas. I think you wanted to know, what humidity extraction level the controls should be set on. If it is really hot and humid in your area, set the humidity extraction level between 35 & 40%. If you have a mechanical control, turn the knob to Maximum.
Hope this helped you, Bradleyjo. Thanks for choosing FixYa.
My Danby R410A dehumidifier is not collecting any water. Are my settings wrong perhaps? Its humid here so it should collect something? Help!
The compressor relay's purpose is to start the compressor. A faulty relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the humidifier.
Before testing a compressor relay, unplug the refrigerator to avoid an electrical shock hazard. Also, if the compressor uses a capacitor, it must be discharged first to avoid the risk of electrical shock.
The compressor relay can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip.
2helpful
Download users manuel for Danby 3 in 1 dehumidifier,
Here is a link to the Owner's Manual you are looking for.
http://www.ajmadison.com/ajmadison/itemdocs/DDR586Rownersmanual.pdf
You can download and print it for future reference.
Hope this helped you. Please let me know. Thanks.
1helpful
Cant find our user guide to the maytag dehimidifier m7dh45b2a, is there somewhere i can down load it or print a copy?
hi ... try to log on the official website (if there's any) of the product manufacturer and then search for the manual of your product... then look for the printable copy... thank you very much...
Top Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Dehumidifier Expert? Answer questions, earn points and help others
