To perform a channel scan using the coaxial input:
Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as “TV,” “ANT,” or the channel and call letters of a station.If the TV input is not selected, press INPUT until the TV input mode is selected.Open the on-screen menu and select TV or Tuner option. (This varies by model.)Highlight Tuner Mode and select the correct option:Antenna—over-the air signals from an antennaCable—direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cableSelect Auto Search or Auto Channel Scan. (This varies by model.)When the search reaches 100% complete, exit to the menu.Check the available channels:Antenna or direct-from-wall cable—Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.Cable or satellite box—Use the cable or satellite remote’s Channel Up and Channel Down buttons.
Go to the Menu and you should find it.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
