SOURCE: Samsung KP-K3 MP3 Player - Charging battery
wen i first got myn i had the same problem i plugged it and left it plugged in for a couple of hours and it showed there bars and was fine i dont quite no wat i did but i suggest double checking you have plugged it in prople sorry if im no help x
SOURCE: Not charging
Try to turn on the Keyboard.
There's a switch in the right side of the Keyboard.
For more information download the User Manual at Logitech Site
SOURCE: SONY VAIO BATTERY CHARGING
This is not a problem, this is a designed function to increase battery life. To adjust this, go to "vaio control centre", and then power management. Inside this is battery care, here you can adjust the settings or de-activate this function.
Firephox
SOURCE: MA2 laptop, not charging battery, changed burnt 4407 chip, no LED now.
This unit had a RED CHARGE error. Replaced PQ38 solved the problem.
If you get an error on the charge circuit after replacing the PQ38 you should also replace PQ38 because it too may be blown. Make sure Pin 1 where the dots. Also check the MOSFET on the other side of the COIL too.
SOURCE: HTC TOUCH HD charging problem
Well hope so you didn't damaged the sensors! try this : use the phone until battery is empty and switches off. then put it on the charger for 4 hours. If no joy,try different battery to make sure that device is not damaged and get a new battery.
