Https://www.manualslib.com/download/334326/Uniden-Bc200xlt.html
Download user manual and read instructions at page-9, your problem will be solve.
SOURCE: i need to know how to program channels into it
HI again, the 248 is only a 50 channel, do you need this info for the 860? If so, I answered in your other post, but here it is again.
Hi tina33, I have an 860 scanner,and this is how I do it. If there is
no freq's in there yet, start on channel 1 and punch in the freq- hit E
and it will enter it into the first channel. Hit manual to go to ch 2
and repeat. If you need freq's for your area, go here and search out
your state and county and it'll give you a list of freq's for your
county.You do not have to add the weather channels as their in there
already, just hit the weather button. I use an external antenna on mine
as it extends the range and allows me to pick up the cars as well.
http://www.radioreference.com/apps/db/
If you need a book for your scanner, you can get one here, just print it out.
http://www.uniden.com/pdf/BC860XLTom.pdf
Hope this helps,, Mechanic
SOURCE: how to program a uniden bearcat bc 145xl 16 channel scanning radio
I'am having a problem. I do not have codes for a uniden bearcat 145 xl 16 channel, can someone help me please?
SOURCE: i am having trouble clearing
hi marie , follow these instructions carfully ,
1. Place
the scanner on it's
back on a hard surface with it turned "OFF".
2. Press
down and hold down
the following keys with your left hand. (MANUAL),
(2) and (9)
3. While
holding down these
buttons, use your other hand to turn the
scanner power "ON". Continue to hold all the buttons down
until you hear a "click" and all the channels are cleared
to 000.0000.
hope thats a fix ya .
SOURCE: lost book to scanner its
do you have a button marked "prgm"
if not, then push the manual button until it
gets to the channel you want to program,
then enter the freq ie... 155.xxx and hit
enter, don't forget the decimal point .
http://www.uniden.com/index/manuals_results.cfm?cat=3
heres a link to uniden bearcat manuals , but i don't see yours .
but my instructions will get the job done .
SOURCE: I have a older uniden bearcat BC860XLT and dont no how to program
Programming steps and many other questions can be answered in the scanner's operating manual, which can be downloaded/printed here:
Bill B
