Question about Coffee Makers & Espresso Machines
I cleaned my single cup flex brew coffee pot and now it only brews a half cup of coffee
SOURCE:
JMuskovitz
  • 135 Answers
SOURCE: brew time
If you have hard water, minerals may have built up in the unit, slowing down the flow. You should be able to find some sort of mineral-dissolving treatment for it at your local grocery or hardware store. Make sure to run a few pots of plain water when you are done, to get any residue out!
Posted on Feb 21, 2007
  • 24 Answers
SOURCE: Coffee maker doesn't brew full pot
you must have a filter and coffee in the basket for a full drain.the weight of the water is enough to open the basket when its full but as your trail run ended the final amount of water is not enough to open drain drop. with filter and coffee in it there is enough weight to keep drain drop open so all water can drain!
Posted on Dec 10, 2007
  • 19 Answers
SOURCE: Coffee doesn't brew full pot
It's possible that the hose or valve running from the tank to the heater is partly clogged. See superkev2000 and W5VSI fixes posted here.
Posted on Jan 19, 2008
skrbin
  • 121 Answers
SOURCE: Sunbeam 10 cup coffee maker starts and stops brewing spuradically
check water heater
Posted on Feb 16, 2009
  • 13 Answers
SOURCE: The "Brew Pause" feature doesn't work
It's the spring part on the bottom of that black basket. Now that it's broken there's really no fixing it. The only thing to do is call the manufacturer (800-726-0190) to get a new brew basket. They are open on weekends, so you could call them today and see what they can do (brew baskets are covered under the 3 year warranty, btw). Just have your model and serial number and you can probably have a new one ordered in less than 5 minutes. :)
Posted on Aug 29, 2009
Testimonial: "Very helpful suggestion to call the manufacturer. I was told to try the self-cleaning, as calcium deposits could be the problem. worked like a charm."
My Mr. Coffee is taking over an hour to brew a pot of coffee
Run a half a pot of vinegar through it then 2 or 3 pots of water. It's from lime and calcium deposits.
Nov 05, 2015 | Mr. Coffee 12-Cup Programmable Coffeemaker
Mr. Coffee single serve brewer won't brew
First clean and please try again
Fill the reservoir with water.
Place your mug underneath the machine.
Add the K-Cup.
Choose your serving size.
Press the brew button to begin brewing.
Enjoy your delicious cup of coffee! .
Sep 25, 2013 | Mr. Coffee BVMC-KG6 Single Serve Coffee...
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
Our coffee maker is only brewing half of the amount of coffee it should. Half way through the brewing, it shuts off. We've cleaned it with vinegar, but it still happens intermittently. It's actually...
Run a 1/2 pot of vinegar through it 2-3 times (I reuse it) and then run water 1-2 times to get the vinegar smell out. This cleans the mineral deposits from your water that are clogging it.
Dec 13, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DDC-2200 coffee maker problem: Sometimes the unit brews less cups than cups of water put into it. Then, after while, you get a brew that give 2 or 3 cups more than what was put into it. The...
Clean the pot by brewing a full pot of undiluted vinegar, then rinsing it by brewing 2 full pots of water through it. Also, change the charcoal filter on a regular basis. We clean the pot this way every month and replace the filter every 2 months.
Jul 18, 2009 | Cuisinart DCC-1200 Coffee Maker
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
Cuisinart DCC2000 quits brewing after 1or 2 cups
I have the same problem with the exact same coffee maker I have tried pushing the 1-4 cups button. That worked for a couple weeks, now it is back to only brewing half the water in reservoir whether I push the 1-4 button or not. It is very annoying.
Nov 14, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Pierre Laplante
Marvin
Marvin
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
