1. If the scanner is scanning, press MANUAL.
2. Using the number keys, enter the channel number where you want to store a frequency.
3. Press PROGRAM. BANK and the bank number, the selected channel number
and CH, PGM, L/O (if the selected channel number is empty), and 000.0000
MHz appear on the display.
4. Using the number keys, enter the frequency you want to store into that
channel, including the decimal point.
NOTE: Your scanner automatically rounds the entered frequency up to the
closest valid frequency. For example, if you try to enter a frequency
of 151.473, your scanner accepts it as 151.475.
5. Press E to store the frequency.
NOTE: If you enter an invalid frequency in Step 4, the scanner displays
Error. Press CLEAR, then repeat Steps 4 and 5.
6. To program the next channel in sequence, repeat Steps 3-5. To program
another channel (not in sequence), repeat Steps 2-5.
SOURCE: police and emergency scanner codes for lewis county?
You can find a short list of police, and EMS freq. CLICK HERE
SOURCE: need to know how to program a radio shack pro-94 handheld scanner
press the "prog" key followed by the "Trunk" key then the number "1" key.
Press the "down arrow" key until you see the initials Ed on the screen
Press the "E" key.
Enter the frequencies (including the decimals)
you must press the E key and the Prog key after each frequency, after you finish entering your frequencies, press the scan key.
If you need to clear your scanner, turn it off, press and hold down the number 2 and number 9 keys, while holding them down turn the scanner back on, "clear" should start flashing on the screen, once "clear" stops flashing you can enter the frequencies.
SOURCE: PROGRAM BC155XL SCANNER
1. Press Manual 1 Manual
2. Enter a Frequency
3. Press E
4. Press Hold (This will advance the scanner to the next channel)
5. Repeat steps 2 through 4
Hope this helps
SOURCE: police scanner frequencies/freelist
Radioreference.com. Go to their data base, Click on your state then your county. It will give you all police/fire ems frequencies.
SOURCE: how to program a radio shack pro 163 police
The 163 is a trunking scanner, so programming instructions are long and detailed, and they vary for each type of trunking system. Programming instructions are best explained in the factory operating manual. If you don't already have it, you can download/print the manual here:
http://www.scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-163-164-OWNERS%20MANUAL_2000164_PM_EN.pdf
You may also want to join a users group for the 163. Check Yahoo or just Google PRO-163.
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
The site also has information that explains the workings of trunking systems, links to users groups, and a lot of other useful scanning information.
Bill B
