Question about Panasonic Look Video Cassette Recorder Ag-7750 Look
Hi, I have a problem with Panasonic AG-7750: He thinks there's a casette inserted, etc... :-/
A moment after turning on the device, he pull-in empty carriage, but then stops by a "pin" in the plastic "chasm" trajectory (on right side). When "pin" is pushed by hand, he "full-load" carriage and loads "" tape "". In addition, there is a small force of loading motor - I must help him with the hand while spinning (he stops otherwise). The left carrier is constantly rotating (grind casette), after insert casette he turns at dangerous speed to the end of tape. (some tape was broken by extreme impact at end). When an empty carriage is inserted, the "S-VHS" indicator will lights up. In general, errors such as E-3 and E-5, sometimes also error E-2. I will try to measure power for loading MOTOR from Power supply, because i seems th e tension is really small... The INFRA-LED has been verified by the camera - shines normally. Alternatively, I can supplement other symptoms in detail: He doesn't have a cassette door (I already bought it in that condition) :-( Thank you soo much! .- AFR
3 Suggested Answers
6ya staff
SOURCE:
David Low
  • 458 Answers
SOURCE: vhs tape won't load completely
I assume the cassette flap lifts fully, allowing the tape to go into the deck as this is a small lever mechanism. When the tape goes so far in, it activates a switch to start the loading motor this is usually a metal or plastic pin on the deck depending on the make of VCR (as you do not mention the model of your VCR, I can only give you an overall explination of a carriage mechanism). The pins at the side can incorporate a start sequence as well & will guide the deck into position. It looks like your machine has gone out of alignment & to solve the problem you would need to remove the cassette housing & re-align the pin at the side so that it follows the correct path, this can sometimes be a tricky & awkward thing to do as you can break parts of the deck if it is not aligned correctly. My advice would be to take it to a service repair centre.
Posted on Jul 22, 2009
Grubhead
Grubhead
  • 5699 Answers
SOURCE: Panasonic AG D555 Tape loading mechaniem not functioning
The Panasonic website might have a free manual of the device if that helps.
Posted on Oct 31, 2012
Sep 03, 2012 | Panasonic Electronics - Others
HOW TO HOOK UP THE PANASONIC AG-7750 TO FLAT SCREEN TV
Look for Panasonic AG-7750 Video Monitor Out at the back panel , then
• connect the BNC connector with cable
• and the other end to your appopriate vacant Flat TV Analog video Input.
For the audio, is just the same .
• Panasonic audio Out to your Flat TV Analog audio In.
Jul 31, 2012 | Televison & Video
Hello i have a jvc rv b 90 . Ive insert the casette wrong. Now i cant open the casette deck anymore.
Hello
Casette tape can be reeled to the capstan shaft and jammed. It is a tricky way to get it out. Only an experienced service technician can do this work. If you try to pull the casette hold tray out by force, it will get broken, and will turn irreparable. OK.
Oct 02, 2011 | JVC RV-B90 Boombox
I'm unable to record with my AG-DVC7. When I turn on the camera , the LCD screen comes on and says "tape not inserted". But immediately I open the tape compartment, power will turn off from...
  • Like all the old video recorders there are mechanical parts inside what need cleaning in high priority the parts that mechanical activate switches for the intake in the little microcontactsswitches and the most important of all are mechanical mode-select-switches where timing is an hot issue
  • The entire process is timed often gears are used, but sometimes also strings that can slip by age and or dirt, cleaning and contact cleaner and look for bad soldering.
  • Also check that the lens motor for the aperture setting is working properly, because everything concerns mechanical settings when that failure then stops the device.
    Also the zoom lens motor that are the first mechanical parts after the tape was lace in. all must exactly done in a special short timing.
PANASONIC AG DVC7 SCH Service Manual free download schematics eeprom...
Apr 23, 2017 | Panasonic AG-DVC7 MiniDV Proline Camcorder
AG-HVX200 firewire disconnect
hello there
first you conect the fire wire on the pc then turn on camcorder if pc dont recognize camera then it seems to have a problem in the firewire board.
must be replaced.
happy new year
Dec 11, 2009 | Panasonic AG-HVX200 Mini DV Digital...
Panasonic ag-dv2500 dv-tape recorder
check the "remote" switch on the front panel; make sure it is in the "off" position. if it is in any other position, the function buttons are disabled.
Jun 23, 2008 | Panasonic Proline AG-DV2500
Panasonic AG-EZ30 - missing reds after bump
As you suspect, it is beyond economic repair. Replacement seems the only option.
May 27, 2017 | Panasonic AG-EZ30 Mini DV Digital...
Panasonic Look Video Cassette Recorder Ag-7750 Look Logo
69 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
