Weve already replaced board and checked the winding and the solenoid.
SOURCE: car will start and run with accelerator pedal held
Could be the throttle position sensor or if so equipped the idle air control valve.
Start circuit bypasses the resister which reduces voltage when running so as to increase amps for better fuel burn. Engine starts on 12 volts for hotter starting spark, but when start mode is released, voltage to coil comes from a circuit which has resistor in it somewhere, often inside a wire so you don't even know it is there. A break in that circuit will act as yours does.
