Question about Video Game Consoles & Games
What happened after modernism - Video Game Consoles & Games
    Master:
  • Video Game C... Master
  • 533 Answers
There is no time....
Posted on May 18, 2019
SOURCE:
How do i clean cmbustion chamber.i understand this will cure cold starting problem
A lot depends on your vehicle. Modern engines with functioning fuel injection systems do not build up combustion chamber deposits like the vehicles of 50 years ago; if they do there is something else happening like bad piston rings or leaking valve guide seals.
In other words, if it is a modern fuel injected engine, if need to clean out the combustion chambers, you need to take it apart and fix it correctly.
Most likely cold start problems are the result of problems with the cold start fuel enrichment system [there are many different systems depending on the vehicle].
Feb 07, 2015 | Cars & Trucks
Plugged heater core
Older heater cores were made of copper and brass. Modern cores are mad of aluminum. An acid would likely ruin the core, but modern radiator flush solutions have chemical buffers to prevent this sort of daamage whils still removing buildups from minerals. Dilute as needed and flush just the core or the entire cooling system. Fresh antifreze and distilled water will keep this from happening again. DO NOT use tap water for a cooling system.
Mar 28, 2013 | Vehicle Parts & Accessories
Call of Duty Black Ops II will not play online
Crowded servers lead to this issue, try connecting at a different time.
Nov 30, 2012 | Activision Call of Duty 4 Modern Warfare...
Ko cai duoc card am thanh
Car batteries can perform a number of reasons. Modern cars rely on constant power to maintain facilities throughout the day and night, such as central locking systems and equipment movement sensor. There are a variety of instruments in modern cars, which require continuous power supply. Without regular recharge a Apple macbook pro battery will eventually go flat. It is also a common mistake for people to leave some operating systems such as indoor and outdoor lights. Again, the effect is the same - the power contained in the discharge of the battery and the battery is flat. The first indication that what happened is that the engine will not start when the key is turned
Nov 15, 2010 | Computers & Internet
Unable to read disk
check the disc for any scratch,try cleaning it using a soft cloth,if still the same issue,try other game disc ,check if it will happen with other game disc,if not, the modern warfare disc is the issue,but if the error persist with all the game disc,the problem is your console you need to call xbox your repair
Jun 30, 2010 | Microsoft Xbox 360 Pro System Console
Call of Duty 4: Modern Warfare Mission Problems
Sounds like a bad disc, the rental place will provide another disc for free within a certain time frame.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jun 21, 2010 | Activision Call of Duty 4: Modern Warfare...
Freezeing
yeah this is happening with me . except i hav an xbox 360. and it only happeneds with cod modern warfare 2.i recentally had a BIG ERROR with my xbox and freezing is only happending now. so maybe u hav an error
Dec 13, 2009 | Sony Playstation 3 (PS3) Console
Modern warfare 2 freezes up have to push main power button to reset......any help?
Hi
Modern Warfare 2 freezing related complaints have hit the web recently, however you can follow these steps to resolve the issue
Clean your disc only if it is dirty.
Install the game on your hard drive and play it that way.
Make sure your 360 has adequate ventilation.
Let me know if this helped
Nov 18, 2009 | Video Game Consoles & Games
Modern toilet cisterns without overflowprovision
Most modern flush units have built in overflow protection, if the water level rises above the flush device then water runs into the toilet itself rather than out of the overflow pipe to the outside as in older toilets.
You could always check by taking the top off the cistern and push down the float device with your finger to see what happens!
hope this helps
Mar 30, 2009 | Facebook Social Network
Video Game Consoles & Games Logo
37 people viewed this question
Top Video Game Consoles & Games Experts
Nikki  Mclean
Nikki Mclean
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
