Question about JVC Televison & Video
Program a onn remote to a jvc tv with a viore converter box?
SOURCE:
SOURCE: Remote control programming codes
i have a GE t.v. and just bought the RCA DTA800 converter box. none of the codes that were in the manual worked for my t.v. can anyone help?
Posted on Oct 06, 2008
SOURCE: Need code for Viore TV to program LG RC897T DVD/VHS Recorder
I believe Viore is the same as Samsung. I only noticed this by accident as I bought a Viore TV and my friend bought a Samsung and I noticed both remotes were identical. I tried the Samsung codes and the remote worked. Good luck! Kevin
Posted on Jan 16, 2009
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Posted on Jan 17, 2009
  • 541 Answers
SOURCE: Avex universal remote programming for Viore TV
Have you tried the search method?Turn the tv on manually. Hold the TV button and the SELECT button down together on the Avex remote until the light comes on. Then use the up (or down) arrow button to scan the codes. Use the up (or down) button slowly but quicker than 30 seconds. If it comes across the right code the tv will turn off. If the set goes off press the power button on the remote to turn the tv back on and test the volume and channel buttons for operation. If some of the buttons don't work continue pressing the up (or down) button until the tv cutts off again. When (and hopefully if) you find the right code press the TV button on the remote again and the light will blink 3 times to indicate it is programmed. I do hope this helps and thanks for using Fixya.
Posted on Nov 05, 2009
  • 11 Answers
SOURCE: Remote Control Program Code
Try the samsung code.
Posted on Jun 08, 2010
ONN universal remote model #ONA13AV269 , I need the codes for Craig brand digital converter box .
If your ONN universal remote has a code search (or equivalent function), you can use it to search for a suitable code. Bear in mind that digital converter boxes often use unique codes to prevent conflict with the TV remote.
Jun 11, 2014 | Televison & Video
I have a magnavox DTV Digital to Analog converter box model TB110MW9 I have lost the remote I do have a universal ONN remote model ONA12AV058 The box is not powered on you need the remote to power on the...
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too
http://remotesearch.blogspot.com/
Check the two links sited here and see to get all setup codes to Magnavox converter. Chekc with that codes. You might have to check more than one code.
Apr 13, 2014 | Televison & Video
Code to program my JVC tv to the DTA800 Digital box
Hi debbie,
I see yiu need a code for your JVC TV to program ti the DTA800.
You can try The codes for JVC TV to program universal remote are 159, 013, 012, 182, 054, 060, 065, 066, 067, 123, 157, and 158. You can check these codes one by one.
I hope this helps.
mvincentc
May 28, 2011 | RCA (DTA800B1) Video Converter
I have a viore tv dvd combo need codes for it
You probably have the same problem that I found after I'd purchased my Viore TV (LC 26VF59), your cable box remote or dish network remote doesn't have the Viore codes built in. Bummer. I looked around and couldn't find codes for my Viore. Doubt you'll find them for yours. Here's a helpful suggestion I read about that works for me:
I bought for $20.00 a Sony RM-VL600 Easy Learn remote control from my electronics store. It's EZ because you only have to place the Sony head to head with the Viore remote, press TV setup and follow Sony's instructions to have its remote catch and learn the codes from your Viore remote. I only programmed my Sony for the Power On/Off, Vol Up/Down from my Viore remote. You back out of Setup and now your Sony will control the TV for those functions. Next you get your cable box or satellite remote put it head to head with the Sony remote, press the CABLE or SATELLITE set-up button on the Sony and then have it learn all the C or S functions you want from that remote. You do program in this mode the Power On/Off button, but you don't program the Vol Up/Down. The volume for the TV will work when you're all finished and operating under the Cable or Satellite button on the Sony remote.
Now, you press the TV button on the Sony and then the Power button. The TV turns on. Now you press the Cable or Sat button and then the Power button and the Cable or Sat box turns on. Like I said, even though now you are operating the Sony remote under the Cable or Sat button the TV volume instructions carry over to this side of the remote so you don't have to switch back to the TV button to raise or lower volume of the TV.
When I'm done watching, I hit the Power off and the cable box turns off. I then hit the TV button and again the Power off button and the TV turns off. So, it's a little inconvenient when starting and stopping, but at least you are using only one remote.
Hope this has helped.
Nov 19, 2010 | One For All URC-3021 Remote Control
Will a universal remote work on a insignia digital converter box?
doublecheck the paperwork for both the converter box and the universal remote. the universal may be too old to be used with your converter. look in the back of the universal's manual to see if your box's corporation has a code you can set.
Jun 12, 2009 | JVC TH-C4 System
Jun 19, 2008 | Televison & Video
Televison & Video Logo
20 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
