SOURCE: hampton bay ceiling fan
This should do the trick. Good luck and make sure the power is off.
L - Orange, 1 - Black, 2 - Yellow, 3 - Purple
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
SOURCE: Wiring the replacement 3 speed switch (fan motor)
I called King of Fans and the rep that I spoke with gave me the correct wiring for the 3 speed switch:
L White
1 Yellow
2 Blue
3 Black
The problem is that after I wired it this way I am getting the same result (off on 3 settings and a motor hum on 1 setting). So, either the Westinghouse switch that I bought at Home Depot is not compatible or it is the capacitor. The saga continues.
SOURCE: I have the aloha model 5745, need to replace speed
I'm an electrician and
I just replaced the speed switch on a 5745. This people at Aloha Housewares, Inc. were very nice and speedy in sending a new unit at no cost.
Connections are:
1=yellow
2=purple
3=black
L=orange
Hello. The most common configuration is: L - Orange, 1 - Black, 2 - Yellow, 3 - Purple
. Here's a link to some troubleshooting advice: http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php and a link to diagrams: http://www.hurontel.on.ca/~taitg/pages/cfan.html
Hope this helps, and don
