Question about Dehumidifiers
Classic dehumidifier MDCDP-45AEN1-BBO Hooked up to continous drain & bucket full light is on. Bucket empty. When disconnect from power source & then reconnect, bucket full light on. Hope you can help.
    Master:
  • 497 Answers
I don't know. my unit has drain hose on bucket. if my bucket is not seated properly, it says my bucket is full.
try to fiddle with the bucket high level float or similar.
Posted on Oct 02, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Dehumidifier Error?
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
Posted on Nov 13, 2008
Anonymous
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
Posted on May 02, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: dehumidifier is saying bucket is full but it is empty
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Posted on May 05, 2010
Mike Squire
  • 420 Answers
SOURCE: 'bucket full' light on, but bucket empty
There is likely a switch operated by a float to turn that light on and turn off the compressor, sometimes manufactures use a rubber "O" ring on the float shaft and they can slip. take the cover off the pump and check the float or in some cases one of two floats are used. Once float turns the pump on and off and the second float shuts OFF the compressor and turns ON the full reservior light.
Posted on Jun 04, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: I turn on the dehumidifier and the red indicator
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
heatman101
Posted on Mar 30, 2011
When full bucket light comes on water is emptied and bucket put back in position. Fan will start and then the full bucket light comes back on beeps and shuts off.
You have to be sure bucket is replaced exactly where it should go or the bucket will hold the switch in, thinking it is full. If you have a floor drain close by,remove the bucket and set the dehumidifier over or next to drain so water will go down it,then you don't worry about bucket getting full.If it doesn't run with bucket off, maybe defective switch. unhook wires to the bucket switch and hook or tape together,if dehumidifier runs then switch is bad. UNPLUG FROM OUTLET BEFORE DOING THIS. IF YOU DON'T UNDERSTAND ELECTRICITY GET QUALIFIED HELP!!
Sep 17, 2014 | Dehumidifiers
I noticed that the "bucket full" light is on and
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
heatman101
Mar 31, 2011 | Comfort-Aire BHD-651 Dehumidifier
Goldstar dehumidifier
The hose connector does not drain the bucket, it drains the condensate before it enters the bucket. Tube passes through back of dehumidifier by the cord wrap area. (you may have to remove a small cover)
Aug 25, 2008 | Goldstar DH504EL Dehumidifier
Dehumidifiers Logo
97 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
