Washing Machines Logo
Jan Barnie Posted on May 18, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GW611 bowl drop problems how do i repair this issue
keith jones
Level 3:
Master:
  • Fisher and P... Master 747 Answers
  • Posted on Sep 08, 2019
keith jones
Level 3:
Master:
Answers
747
Questions
Helped
314784
Points
1478
Would need more info
I have fisher paykel GW611 making a terrible squeaking sound when washing. It seems to be coming from under the white plastic fan like thing under the machine. Need help to get it off Thanks
What do you mean by the white plastic fan? Do you mean the round bowl part of the motor in the centre or the small fan on the drain pump on the front right corner of the bowl?
FP Model GW611 Washing Machine intermittent & slow water flow into bowl then machine times out or errors. Removed inlet flow restrictors, fan on pump turns freely?
valves are wearing out and need to be replaced. they are located behind the top board where the hoses plug in. turn off water when removing valve tops!
2answers
Korky anti-siphon. Tank water slowly drops, accompanied by a hissing sound. Then, after dropping about 1/2 inch, it refills. Wha?
either the fill valve is running and water is draining into the bowl via the overflow tube in the tank or the flapper is bad (or foreign matter) and it is allowing water to escape into the bowl slowly...causing the fill valve to run every few minutes or so. hope this helps but if you need anything else just text me here:)
Our GW611 has problems draining. Washes OK, but when it moves to the first rinse where it is spinning and taking on water at the same time it is not draining fast enough and goes out of balance. It...
Hi - it would seem to me as if the pump is ether overheating or you have a restriction with the drain hose or a combination of both, you need to remove the pump to check it out.
The pump units on F & P washers will pulsate thru out the spin cycles, if H2O left in the bowl then theres a problem with the drainage somewhere.
If theres no blockages found then the pump will need to be replaced...
KK
Honda GX160 5.5 horse power The engine won't start . It almost starts for a second and quits. When I took off the air filter and put a few drops of gas in , it started for about 10 seconds than quits .I...
make sure you are getting fuel to the carb and make sure the float and seat in the bowl move freely and all is clean and clear. this sounds very much like a fuel issue,, also - while you have the bowl off the carb -make sure you spray carb cleaner into the jet and seat area.
if you are still having problems --please feel free to write me back here and I will do my best to walk you through the repair steps.
c...
Fisher & Paykel GW611 Not filling with water
Hi just read your posting.Did you remove any wires to the control module which is located under the top panel when you replaced the bearings.Now did you put the cold inlet hose to the water valve marked with the letter C and the hot to H ?These letters are next to the valves.Have you got the Efficiency option button?Can you select a manual water level instead of just an auto fill?Have you tried to put the machine throe a spin cycle?Do you hear any water coming into the machine at all?Please with additional information to these questions and I am sure we can rectify this problem for you.
Model gw611 where do you find the pump
The pump is located under the machine,Look for the plastic fan.Also to remove it is easy.Unplug the the earth and power plugs,And there is a plastic lock that has to be held out while turning the pump anti clockwise and it will drop out.Hope this helps.
1helpful
It is a GW611 excellence model.It will not go past rinse cycle on
I spoke to a person yesterday that has a next door neighbour that does washing machine repairs and he is going to look at it so i can let you know what the outcome is if you want to know.Thanks Peter.
1helpful
Leaking Dark Oil
Sounds like a combination of two issues.
1. In all likelyhood, the viscosity of the lubricant in the main transmission of your mixer has broken down and is now oil rather than the grease it once was.
2. The seal on the main transmission shaft is worn and the "oil" is leaking past it, resulting in drops of oil forming on the bolt head at the bottom of your planetary and dripping into your bowl.
Draining and replacing the lube and seal is a rather involved repair. To do it properly, complete transmission disassembly is required.
If it was my pizza business and there's just a drop of oil here and there ( 1-3 drops in the bottom of bowl in the morning ) I'd let it ride, keep wiping the oil away prior to mixing a batch and budget (apprx $500-$600 ) for a proper repair as it becomes worse over time. Unfortunately, it won't get better.
I'll add.
It's been my experience that D300's and pizza dough don't play well together. Be certain to calculate the weight of all your ingredients and then consult the capacity chart found here. http://www.kroslakbakeryequipment.com/pdfz/HOBD300.pdf
Stay within the guidelines and you should be fine...however your batches will be rather small.
Hope this is of some use.
Bowl won't lock into Place
hi have a nice day.
At the link below you can find illustrated instructions of how to repair a food mixer.
http://home.howstuffworks.com/how-to-repair-small-appliances4.htm
Does it help?
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
