Car Audio & Video Logo
D
Dan St Jean Posted on May 18, 2019
My 12” jl audio W6 V2 has a burnt voice coils. What parts am I going to need to fix it. Jl W6 V2. The last answer I received was for a older W6 thanks.
5 Related Answers
A
Anonymous
  • Posted on Mar 13, 2008
SOURCE: jl 13 w7 burnt voice coil
Nope!! I burnt up my 12W6 from supposedly under powering it. Your going to have to pay for a new coil if under factory warranty. Other wise ..... spent good money on a paper weight. Sorry for your loss, I know that I was pissed. :-(
smarthome2
Frank Fulton
  • 1114 Answers
  • Posted on Jun 14, 2009
SOURCE: I have a JL Audio W6 that is torn in the front
If it it the surround that is torn from the speaker, use clear silicone, it does not harden, and bonds very well. use "100% silicone" Hope this helps
Joel Friedenberg
  • 1114 Answers
  • Posted on Jul 01, 2009
SOURCE: jl audio w6 surround repair
If you're willing to do the repair yourself, there is an Internet site - Simply Speakers -that sells repair kits for speakers ,including speaker surrounds.
I did two 10" drivers and it worked 100%. ..
Anonymous
  • 655 Answers
  • Posted on Sep 13, 2009
SOURCE: how 2 wire 3 jl audio w6 v2
Hello mikey4569mky,
Unless your amp is stable below 1 ohm, there's really only one wiring solution. And that is to series the voice coils making each sub 8 ohms, then parallel all 3 subs to the amp for a 2.67 ohm load. If you parallel the voice coils and then parallel the subs, the impedance will be 0.67 ohms, much too low for most amps.
You could parallel the voice coils and then series the subs for a 6 ohm load, but the amp won't put as many watts into a 6 ohm load. Most are optimized for 4 ohms or 2 ohms. And it's not good to run subs in series anyway.
Here's the wiring diagram.
Hope this helps.
Anonymous
  • 21 Answers
  • Posted on Feb 10, 2010
SOURCE: What size amp or watts needed to power a JL 12
these subs are rated at 400 watts rms ... hope this helps
1helpful
Box size for jl audio 12"w6 going in large trunk
call jl they will give you BEST box recommendation
If you need further help, I’m available over the phone at https://www.6ya.com/expert/stephen_fa62cb6d50fe05e8
JL W6 ohm wiring issue
Parallel , all positives together , all negatives together . With 4 ,4ohm voice coils in parallel you get around 1 ohm .
My 12 w7 makes a noise when I push down on it, what's wrong?
first of all the coil might have overheated and slightly made the voice coil go out of round or one of the biggest problems that jl has with their w6 AND w7's is that the magnet shifts because of the glue they use if its not annoying just keep using it or you can contact jl which by the way they charge about 250 to recone it plus at least 50 to ship and i dont think they pay for shipping to send it back you pay that also
I have a jl audio w3 that doesn't play or make any noise. I bought it brand new, never had been installed. Pressing the cone feels smooth and precise, so there is no signs of the coils being burnt out. The...
Id say take it back to where ever you bought it from and get an exchange. Have them test it there and see if it works. I have a JL W6 and have had JL's for a long time.To hear of something like this with a new JL is very rare. Just may be some kind of defect. Bring it back, get it tested and go from there.
Who to wire JL audio 12w6 to its max
Hello shermalestuc,
The JL Audio 12w6 v2-D4 has dual 4 ohm voice coils that can be wired for either a final load to the amp of 2 ohms (parallel) or 8 ohms (series).
If your amp is 2 ohm stable, the best power solution for a single sub is to use the parallel configuration, both positives and both negatives together and then to the amp.
How 2 wire 3 jl audio w6 v2
Hello mikey4569mky,
Hope this helps.
2answers
JL AUDIO 12W7-3 SUB
the rottem electronic smell is the voice coil burned up as well as the bad sound, isn't the 1st time i have seen a JL sub blown. not worth fixing buy a new one the cost is not that much more repair on them is 250 - 450 depending on how bad it is and only JL can do the repairs as they dont authorize repair shops access to their voice coils. however i can sell you a new sub with full JL factory warranty drop shipped to your door for about 475$ or I could do you a way better sub ( the baddest competion sub made in the last 5 years) an olympus 2412 dual 2 ohm 5000 watt monster that has user replaceable voice coil options and is killing the competition circuit right now for about $275.00 shipped. it will stomp 2 13 w7's into the ground all day long. 2 subs vs just 1
Need a new surround for '96 JL AUDIO W6 12"
Call Jeff at California Sound in Wichita, KS 316-686-2254. He is a JL expert!
Jl audio 12w3v4....both smoked and fried on a 500/ jl amp
Unfortunately, it sounds like the voice coils burnt up. There are places that do repair, but for these particular subs, it would be more cost efficient to replace them. I also doubt they are salable, but ebay is a magical place.....
Jl 13 w7 burnt voice coil
Top Jl Audio Car Audio & Video Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
