Question about Frigidaire Washing Machines
I have frigidaire FTF2140ES0 we cleaned bellow now machine foesnt work
2 Suggested Answers
SOURCE:
SOURCE: FTF2140ES0 Bellows Kit replacement
remove and install a new bellows kit for a Fridgidaire front-loading washer model ftf2140es0
Posted on Jul 05, 2010
When was FTF2140es0 was made
Good Evening Ami, that's a great question!
I understand that you would like to know when your Frigidaire washer was made. Based off the model number you have provided your washer was produced in 2005. I hope this is helpful. -Matt
Jun 12, 2015 | Frigidaire Washing Machines
Frigidaire FTF2140ES0 Front Load Washer lock indicator light goes off, but will not spin.
Sounds like the electronic locking mechanism is malfunctioning. It is supposed to enguage before the high spin cycle. It is about a $20 part.
Sep 20, 2011 | Frigidaire GLTF2940ES Front Load Washer
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
My frigidaire washer FTF2140ES0 won't spin on the spin cycle
Hi there, the same thing is happening with our washer. Did you find a solution to the problem? We found a coin the the black tube, but it still doesn't do the final spin. I can hear the motor trying to do something, but it just won't do the final spin. If anyone has any idea or suggestions it would be greatly appreciated. In the meantime, I have a load of slopping wet laundry to deal with. :(
Jan 04, 2010 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Nov 09, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Need a restart code
Press & hold down the 'options' & 'select' buttons for over 3 seconds. And let me know. These are the buttons, but how long?
Mar 19, 2009 | Frigidaire Affinity ATF7000E Front Load...
Bad odor
glisten and affreash is the cleaning agents
besides this only way to get smell out is a complete inner and outter tub job but also try leaving both soap dispenser and door open for the air to dry up and vent the washing machine
Feb 24, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
FRONT TUB SEAL HOLDING WATER
no fix ..ALL BRANDS have same issue just ck out other web sites best solution ..leave door open as much as possible ..clean out boot with bleach/water solution at least once a month..CHLORINE BLEACH!! and no not the answer you wanted but best answer you'll get and that from experience
Nov 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Fridgidaire FTF2140ES0 Front Load Washing Machine Vibration
Try going to GVIINC.net - there product definately works.
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
