Figure out if its a blown coil or damaged cone
1. Blown Coil:
The voice coil is the component, which amplifies the current run through the speakers. If you doubt that the coil is damaged, connect the terminals of the coil to a multimeter, and if there is no resistance detected, it could be because the coil is damaged.
2. Damaged Speaker Cone:
If there are no issues with the coil, the next possibility can be a damaged speaker cone, which can be detected easily. In normal condition, since the subwoofer is built on a suspension system, the cone is easy to move. Look for the following signs to understand that your speaker cone is damaged:
Once you make sure that you have a blown subwoofer, the next step will be deciding on how to replace it. Imagine if your subwoofers can be fixed easily with minimal efforts within a set budget rather than buying a new one.
Then
1. Detaching the speakers:
Use a screwdriver to take the speakers from the place where it is mounted and take off the attached wires. After that, separate the surround and the frame by removing the glue on the frame edge by using a small knife or a sharp object like a tester edge. Be very careful when you do this because the frame edges can be damaged.
2. Separate the voice coil and speaker cone:
Using the same small knife or a tester edge, slowly take out the voice coil from the speaker cone. Cut all the terminal wires and keep the voice coil, speaker cone, and spider separately in place.
3. Fixing the new voice coil:
Clean the trapped dust particles in the voice coil gap carefully by using the compressed air. The voice coil is the piece of wire that is attached to the speaker cone, and that is responsible for amplifying the current, which is passed through the speakers. Remove the old voice coil and fix the new voice coil within the space if the problem is with the coil. Place the spider around the new voice coil, replace the spider and then the speaker cone in the middle. Don't forget to apply enough glue so that the cone doesn't come out. Let it dry for about 24 hours.
4. Fixing the speaker frame:
After it is dry, apply glue on the surround to fix the speaker frame and the cone in the right position. Now we are about to reassemble the components of the sub-woofer.
5. Fixing the wires:
Once all the components are put together in the right place, use a soldering iron to connect the old terminal wires with the new voice coil terminal wires, if the voice coil is replaced. If the new cone has no pre-attached wires, use small wires to the terminal wires, and then create small holes in the cone. Place the wires into the holes and connect them to the voice coil using the soldering iron.Now the connection is also reestablished.
SOURCE: jl 13 w7 burnt voice coil
Nope!! I burnt up my 12W6 from supposedly under powering it. Your going to have to pay for a new coil if under factory warranty. Other wise ..... spent good money on a paper weight. Sorry for your loss, I know that I was pissed. :-(
SOURCE: JL AUDIO 12W7-3 SUB
the rottem electronic smell is the voice coil burned up as well as the bad sound, isn't the 1st time i have seen a JL sub blown. not worth fixing buy a new one the cost is not that much more repair on them is 250 - 450 depending on how bad it is and only JL can do the repairs as they dont authorize repair shops access to their voice coils. however i can sell you a new sub with full JL factory warranty drop shipped to your door for about 475$ or I could do you a way better sub ( the baddest competion sub made in the last 5 years) an olympus 2412 dual 2 ohm 5000 watt monster that has user replaceable voice coil options and is killing the competition circuit right now for about $275.00 shipped. it will stomp 2 13 w7's into the ground all day long. 2 subs vs just 1
SOURCE: have a jl 500.1 amp
for that amp u need a compasitor to mantain the amps the amp draws the amp is being choked when the car is off and when its running its killing the cars charging system
SOURCE: jl audio w6 surround repair
If you're willing to do the repair yourself, there is an Internet site - Simply Speakers -that sells repair kits for speakers ,including speaker surrounds.
I did two 10" drivers and it worked 100%. ..
