Question about Generac Electrical Supplies
What could be the cause of overspeed error on a 15-year-old 15 kw stand-by Generac Guardian?
We have a 15-year-old Generac Guardian 15 kw stand-by generator. It has about 108 hours of run time on it. Battery was just replaced, and oil and filter were recently changed. Today during its scheduled run cycle it struggled to start-up then stopped running after about 5 seconds. It has an overspeed error and a popped spark plug won't go back in. It will run, but for no more than 60 seconds. Any idea what could be causing this? Is it something that we could potentially repair? Or, is this a job for an expert?
    Top Expert:
  • Generac Master
  • 30,148 Answers
Go here, join and ask any questions you have. these guys are all installers and experts in the field. good luck
https://www.zillerstore.com/
Posted on May 17, 2019
2 Suggested Answers
SOURCE:
SOURCE: Generac Guardian 15 kw overspeed fault
Did you remember to set the overspeed shutdown threshold on the control board?
Posted on Jun 07, 2010
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
Generac Guardian 12 KW Model 04456-2 shuts down on overspeed in cold weather
Leigh,
See my 5/22/12 comments on my "overspeed fault" problem resolution [Generac 43903 standby Generator overspeed indicator on starting] . If it only runs for a few seconds and then quits, you may have a similar condition to the one my unit had. A good technician should be able to diagnose the problem and determine if you have a similar failure to the one I had, or one of the other causes suggested by RSG000.
Jan 20, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
I have a generac 22kw model QT02224anan that will run for a few minutes then shut down , then the over speed led is lit. It only happens when it is under load or during a power outage. it goes through...
its possible the overspeed is set to sensitive. or your rpm are to high. these are preset in the factory as a safety, check your manual to ensure your rpm speed is in the pre set area. generators will do this under load when you have a big load on them or take a load off. the governor will some times over compensate causing it to trip on overspeed.
Aug 10, 2011 | Generac Power Systems Generac QT02224 22...
Hi: I have a model 0052411 Guardian generator that is putting out 170 volts. Anyone have any idea what has caused this to happen. It has fried any transforms that are in the house. Generac is not much...
Check the automatic voltage regulator .Or if you have a bad neutral connection one leg will be very high and one leg low causing damage to sensitive equiptment.
Oct 19, 2010 | Generac Guardian Series 5502 10 kW...
Unit shuts down from overspeed fault unit has 35 hours total run time never ran more than 2 hours 45 minutes rest is excerise time . is this problem with the 15 kw common ?
The engine throttle control is out of adjustment. It needs to be set based on the generator frequency
(60 Hz).
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 22, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
10kw Generac shut down overspeed
Make sure that the throttle linkage is all there and not damaged/misadjusted, then get a manometer and check your inlet gas pressure. Gas pressure should be 8 inches of water column and stay there running or not.
Carl
Apr 06, 2009 | Guardian Electrical Supplies
Apr 03, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Electrical Supplies Logo
64 people viewed this question
Top Generac Electrical Supplies Experts
Sheldon Dedek
Bob Janelli
Level 1 Expert
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
