Tools & Hardware - Others Logo
Stephen Halaby Posted on May 17, 2019
I have a Goulds J10s, the pump housing gets very hot. seems to be working but it's incredibly hot
[email protected]
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 17, 2019
d1k@sbcglobal.net
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
593
Points
Check incoming voltage umder load. if its under nameplate volts when running you have overcurrent. check fan inside housing for damage or blockage. finally check disch pressure to make sure no restriction blockage in line. Im Pentair engineering person
2answers
Trying to find part numbers for ao smith model c48a95ao6 shallow well pump motor shaft bearings
notify goulds -----https://www.gouldspumps.com/en-US/Home/ or online search and open one of the 1000's of part sites
Goulds GT07 Irri-Gator Centrifugal Pump. It is a brand new pump is leaking.
Question edited for clarity.
Question moved from Cars and Trucks to a Goulds category.
Contact the maker of the supplier. It sounds like they left out a gasket or seal.
https://www.google.com/search?q=Goulds+GT07+pump+leaking+water
Goulds j5s pump discharging rusty water and green moss particles. how do i flush
If its discharging all the time, I would say its sucking up contaminated water but if only occasionally, that would suggest something is rusting / deteriorating in the system and it "grows" when the pump is not in use. I would have a close look at the source tank(s), the connecting pipework and as a last resort, disconnect the pump and have a look inside the pump chamber.
Goulds pump troubleshooting
If a pump makes that sound it can mean it is not properly lubricated, or in oyur case does not have enough water passing through., and serious damage can result.. Get in touch with an agent like
http://www.pumpagents.com/GouldsPumps/Jet_Pumps.html
Water pump for the house keeps re-cycling, without using water
IS THE TANK WATER LOGGED? THERE HAS TO BE SO MUCH AIR IN THE TANK TO KEEP PRESURE.
Goulds pump
check for air leaks in the connections our your pressure switch is bad
Pump comes on shuts off then comes on shuts off
In other words, it is cycling quickly. Check your bladder tank for proper air pressure. You will have to shut the pump down and drain the tank to do this as the pressure in the bladder is set when the tank is empty, or nearly so, no pressure on it. Set air for a couple of lbs below the normal on point of the pressure switch. If you don't know what it is supposed to be, start at 28PSI, after pump is working, check system pressure while it is under load, meaning turn on the water and let it run and watch pressure gauge for when pump comes on. If no pressure gauge, install one as you need it to see if you system is working properly. It it isn't a bladder tank, just an older style tank, same thing, same procedure.
I have a pump that will not pump higher that 40 psi. There seems to have plenty of water to the inlet, it is even gravity flow no suction needed. This pump is about 9 years old and recently during a flood...
The Goulds J5S pump is only rated for 40 psi. Is it possible that is the correct operating pressure? Did you get a higher reading in the past?
Dec 27, 2010 • Plumbing
Water stopped running in house, I was running hose for about an hour and water justed stopped. reset breaker and still no water
take the screws out of the bottom of the pump maybe sand in the impeller.that pump s/b off the bottom of the pit on like a brick or something
Top Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
