Heating & Cooling Logo
soapy Dogs Posted on May 17, 2019
I have a Dometic rooftop air conditioning unit for a trailer it's just blowing warm air any suggestions how to fix this
See if compressor on if not possible start up capacitor if ok bad compressor or low Freon make sure fan on auto
  • Max Muller Oct 14, 2020
    how to contact you? I have a man that could repair it
  • Anonymous Oct 25, 2020
    Yeah, I know ur feeling. How many times I've been tripping with my wife to mountains in summertime in my car and how many times my air conditioner had given disfunctions just in the middle of the road where I didn't have a place to stop and park the car for a few seconds. That has been really a huge problem for us, but thankfully we got suggested some guys fromhttps://www.socool.sg/ that could help us fix that, and not for a high price aswell. And by the way, since they helped us that thing never broke again. Hope it works for you aswell !
JammEr21
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 29, 2020
JammEr21
Contributor
Level 1:
Answers
Questions
0
Helped
603
Points
I'm sorry for posting here but I have the same problem and I want to know if you managed to find a solution
5 Related Answers
Anonymous
  • 106 Answers
  • Posted on Jun 09, 2008
SOURCE: Air Conditioning - blows warm
Hi
If the fuses are all ok and you can hear the aircon clutch clicking when you attempt to switch it on, then I think it may be time for a re-gas! You could do it yourself with a can of gas from an autofactors, but you wouldn't get the pressure right, and, there would still be old gas in there.
If you took it to a garage, however, they would **** out all the old gas, and then hold the vacuum in there for a while to check for any leaks. Then they would refill to the exact pressure with fresh new gas.
Regards
Geordie
Anonymous
  • Posted on Jun 29, 2008
SOURCE: air conditioning blowing warm air
my dodge is overheating and the a/c is blowing hot air. i replaced the thermostat but the problem continues. help!
Anonymous
  • 14 Answers
  • Posted on Apr 06, 2009
SOURCE: coleman tsr rooftop airconditioner
NEED A FREON RECHARGE AND MAY POSSIBLY HAVE A FREON LEAK
STEVE'S APPLIANCE
516-300-3249
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Jun 05, 2010
SOURCE: Rooftop RV Air Conditioner: replaced capacitor on dometic 59516-531 steal trip...
You need to borrow a clamp on style amp gauge, and check amp draw on black wire in box where hydro wires connect. (PLEASE, be careful, and if not experienced in this type of test, don't try it, due to likelihood of getting a shock. ) If it's the compressor kicking in that's causing the breaker to trip, and capacitor is good, then it's usually a problem with either low incoming (supply) 110-120 AC voltage, which will cause high amperage draw, or compressor on it's way out causing high amp draw. If it's only drawing 15-18 amps, and your tripping a 20 amp breaker, then breaker is getting weak.
Anonymous
  • 110 Answers
SOURCE: air conditioning blows warm at idle cool when driving
hello there:
you may have a blockage in the system and then again it could also be low on freon and may just need to recharge and i would suggest taking it to an a/c repair shop and have them do a diagnosis on the a/c system it should not be more than about $150 for them to check system and recharge the system unless you have other problems hope this helps you out please leave a review thanks sincerely D.Jones
2answers
My Dometic Rooftop 15000 BTU Model 459516.701CO will come on and run and then shut off it continues to cycle within minutes of shutting off it is controlled by a Dometic Comfort Control Center 2...
THE OUTSIDE FAN MOTOR MIGHT NOT BE WORKING CAUSING THE COMPRESSOR TO GET HOT AND TRIP THE INTERNAL OVERLOAD IN THE COMPRESSOR - IF THE UNIT IS LOW IN FREON SAME RESULTS - WHEN UNIT IS FIRST TURNED ON DOES IT BLOW COLD AIR OR DOES THE AIR NOR FEEL COOL - JUST COOL AIR COULD BE LOW FREON - COLD THEN WARMS UP IS FAN PROBLEM
I have a dometic penguin ac rooftop unit. Model no. 630215.421. Fan blows Compressor does not kick on. Fan blows just no cold air. If put on auto and go up or down in temperature On the thermostat The fan...
Bad run capacitor or bad compressor. If you hear an occasional click from the compressor try a new run cap and then a hard start kit. Otherwise it's more economical to purchase a new unit.
My ac doesn't blow cold
Can you hear the compressor starting? If so, suspect broken pipework and loss of refrigerant. If not, suspect loose wire to compressor or thermostat
1helpful
We have a Brisk Air in our 1991 Jayco Eagle. The travel trailer is from Rhode Island and we're not sure if the air was ever used. The unit turns on, the compressor engages but doesn't blow cold air, only...
Really sounds like the compressor isn't coming on. Go on top of camper and take the housing off. Now then engage the air conditioner and feel the compressor. Touch the copper lines to feel any temp. change. Now then if it isn't coming on look for the capacitor. Silver looking can that is the item to check. They are duel purpose they run the fan and the compressor. Unplug the electricity and remove the capacitor remembering the wires and were they went. Now take to parts house and they will be glad to check it. Should only cost about 15 bucks for new one. Get the same rated size. be good to go. ken
I have recently replaced the fan motor on my Briskair roof top A/C unit, should the squirrel cage draw air from inside the trailer and blow out rear of the unit, or have I installed this fan incorrectly?
Yes the air should be drawn from the trailer, over the cold coils and then
back into the trailer, whether rear or front.
The condenser coils should be self contained on top and blow
warm air outside the trailer
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
[email protected]
Top Dometic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
